rod bearing question
  • streetknight
    • Oct 2005
    • 236
    ok i have called bavarian and the gave me the size for the main bearing, but cant find the size for the rod bearings so ill try the boards. for a bmw id # i have
    843
    1284
    844
    any one know if its standard or oversize?
    • 34844
    the easiest way to tell is to look at the color coded dots on your crank, the bearings are sold color coded to your crank.
    is this an M20/M50? if so there are only 2 sizes, red and blue. check realoem.com for the specs. all BMW bearings are the same btw, from the earliest M20 to the S50..
    • streetknight
      • Oct 2005
      • 236
      its a m50 with a s50 crank. thats why i want to make sure which goes in. thnaks ill try the link
        • 34844
        it's all the same; look for the paint marks on the crank and match them with the bearing sizes.
        • streetknight
          • Oct 2005
          • 236
          where on the crank.
            • 34844
            mine were on the counter weights.. should be fairly obvious paint dots, but they might be covered in grime by now.
