M20 vs M52 dyno comparison
  • übersteuern
    • 45
    In case anyone's interested, I did a dyno comparo of before and after engine swap. Same drivetrain, same dyno:
    - M20B25 99 kw (133 hp), 177 Nm.
    - M52B28 126 kW (168 hp), 236 Nm.
    The dyno sheets say Autronic, but I'm not sure if this is the type of dyno or just the software (so, yes, I have the dyno sheets if you doesn't trust me!)
    Both engines were running well and unmodified, except the M52 swap included a custom exhaust and maybe some mixture tuning.
    Unfortunately, they didn't use an exhaust probe for the M20. But I made sure they did for the M52:
    - up to 3500 rpm, it cycles around 14.7 (the dyno guy said the fluctuation is due to closed-loop, but I thought these engines were meant to be open-loop at WOT?)
    - above 3500 it quickly dives down to 11.5 - 12, where it remains until redline.
    The DME is supposedly a stock tune, but the EWS had been removed, so there is a possibility that a different tune got in there somehow. Maybe this is the cause of the strange mixture readings? Or perhaps the car has a faulty O2 sensor?
  • 328ijunkie
    • May 2007
    • 3961
    Seems fairly accurate...
    Check Us out on Facebook
    Full Product Line Tuning
    • berlow94
      • Jan 2013
      • 1063
      Just about normal for 20+ year old electronics...
      Closed loop with a narrow-band o2 is probably going to fluctuate equally as much as just regular open loop
      The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
      • übersteuern
        • 45
        Sorry, what do you mean? I didn't think open loop would fluctuate?
        My understanding was the motor should run open loop at WOT, regardless of rpm?
        • 328ijunkie
          • May 2007
          • 3961
          MS41 basically shuts off fuel trims at WOT, it does add/remove multiplicative (or LTFT) to the WOT fuel map however.
          • digger
            • Nov 2005
            • 6198
            Post up the graps on the same sheet if you can. I bet it reveals more than just looking at the peak numbers
            • übersteuern
              • 45
              Ahh. Thanks for the explanation.
              Just noticed your dyno thread, think I'll have to spend a few hours going through it :)
