S50B32 run-in tune dyno video
  • Brisbane E30
    • Jan 2013
    • 99
    Well Red Rocket is alive with a new heart transplant. The car was on the dyno last week to give it a run-in dyno tune. I'm very happy to say that the car made 330whp@7,000rpm. Calculating in a 20% drivetrain loss that equates to about 415hp@the crank. Considering that it is not all in and the fact that the engine was only turned to 7,000rpm (built to turn to over 8,500rpm) I am very happy with the results. I reckon that it sounds pretty nice too.
    E30 318is S50B32 powered
  • nrubenstein
    • 3148
    So, how exactly was the motor built? 330whp is way high for the S50B32.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Brisbane E30
      • Jan 2013
      • 99
      Do you mean what is done to the engine?
      It has been rebuilt with 12.5:1 CR, 1mm oversize valves which have been multi-angled. The cams are massive "race only" Cat Cams with massive lift and duration. Everything in the engine has been replaced. Shim under bucket conversion. ECU is a Motec M84. Vanos has been deleted. Etc, etc.
      • Bglad
        • Jul 2010
        • 562
        20% drivetrain loss is pretty Impressive. It's more like 10%. How did you quantify the 20% loss? Also, what dyno was used, and what parameters? I can make a stock M20 read 400whp with a couple tweaks to the settings. Dyno's are no more that tuning tools, and never accurately reflect power.
        • Brisbane E30
          • Jan 2013
          • 99
          Good for you!
          • Bglad
            • Jul 2010
            • 562
            Still didnt answer my questions.
            • Brisbane E30
              • Jan 2013
              • 99
              A little perspective - same dyno, same operator, same conditions my mate's E46 M3 CSL made 265whp.
              Of course a dyno is just a tuning tool, and out right numbers don't necessarily mean a whole lot.
              But it's a good place to start and I can track the delta change when the all in tune and run is done.
              • Brisbane E30
                • Jan 2013
                • 99
                And I don't intend to. None of it matters.
                You're not impressed. That's cool. Not here to impress you.
                • Bglad
                  • Jul 2010
                  • 562
                  My 90 Honda Civic Si makes 152hp/140tq based on a 20% drive train loss. So basically what youre saying is that a 108hp engine makes 50 more hp from an intake and exhaust and a tune?
                  All I'm saying is, you need to fundamentally understand power conversions and distribution. Not saying thats not a healthy motor, but boasting about power is just bragging to impress. Also if you jack the tire pressures up to 60psi so you have less rolling resistance is usually worth a few more ponies ;)
                  • Bglad
                    • Jul 2010
                    • 562
                    • Brisbane E30
                      • Jan 2013
                      • 99
                      Who's boasting? Certainly not me.
                      And it's a hub dyno. No tyres to pump up.
                      • burkey001
                        • Feb 2011
                        • 608
                        well, i think its awesome :)
                        88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
                        90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
                        • Brisbane E30
                          • Jan 2013
                          • 99
                          Cheers Burkey.
                          Car comes home this week.
                          Next weekend it will be on display at the Mt Cootha Classic Hill Climb and then the week after that should be time for the full-house tune.
                          What size wheels and tyres were you running on your car?
                          Ive got 225/35/18 at the moment and there isn't a whole bunch of traction there. Also not a whole bunch of room for meatier tyres. Thinking of running 225/40/18 R comps (R888, Advan etc).
                          • digger
                            • Nov 2005
                            • 6181
                            s50b32 are awesome, do you have a printout of the graph? i'm interested to see the torque curve sans vanos.
                            a hub dyno has way less losses than a twin roller dyno as the tyre deformation is the biggest loss, but still must be plenty of power and fun in an e30
                            what cams and who did the head? any flow numbers?
                            • nrubenstein
                              • 3148
                              Well, that explains that! Awesome to see strong results from that. :)
