M50 AC Idle Bump
  • glucklich21
    • 1912
    M50 AC Idle Bump
    I just finished up my swap and thought this would be helpful for those who don't want to do some reading on getting their AC idle bump to work.
    I'll have some more documentation later on the actual AC install on a 24v swap e30 once I complete it.
  • sublimation
    • Jul 2013
    • 155
    So, there is a wire coming off of the snowflake switch that should ground pin 6 when depressed?
    • benz-tech
      • Jan 2011
      • 381
      I tried grounding that idle bump pin at the DME just to try it and no bump. My car is and obd2 M44 cyl tho.
      You say "Where are your other two cylinders?"
      I say "Where's your other camshaft?"
      Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
