m52b28 stroker
  • M50Power
    • Aug 2014
    • 40
    m52b28 stroker
    hello, recently i've built m52b28 stroker 3.3l with 87mm bore, i installed m50 non vanos dual valvesprings on my m52 head, can i rev this engine 7500-8000 rpm safely? there is 0.5mm deck clearance and 1.75mm head gasket
  • digger
    • Nov 2005
    • 6213
    i hope you use a ATI damper so you dont shake the bottom end to bits.
    what cams? more than likely there is no need to rev that high with that big of an engine
    • 328ijunkie
      • May 2007
      • 3961
      Youll need an ATI dampener to rev an S52 crank over 7200 reliably. M52 crank is another story but either way your power on S52 cams will start tanking after 7050...
      Check Us out on Facebook
      Full Product Line Tuning
      • digger
        • Nov 2005
        • 6213
        when he said 3.3L and 87mm bore than means a stroke well over 90mm ??
