I can not get my temp to go over 86 celsius unless I allow the car to set at idle with the electric fan off. With that in mind, I am running a stock temperature thermostat (motor is from an e39), e30 pusher fan, e36 radiator, and an adjustable temp fan controller. I replaced the t-stat thinking that it was stuck open, but I was wrong. For reference, this is an OBD2 car, so I am pulling the temp data from INPA.
Is my temp sender off a few degrees? Do I need to get a cooler t-stat? Any other ideas?
