Suggestions on coilpacks melting and no start?
  • helghit
    • Jun 2015
    • 29
    So I recently got my m50b25nv running after replacing the crank senso (very badly I must say), It idles rough and I thought maybe one of my cams were out of time but I triple checked the motor when putting it together, Anyway after running badly I replaced all of the coil packs and noticed the ground straps that are usually on there were non existent which led me to believe there was too much resistance. So I got some random wire and grounded all of them to no avail of making it run better. Then the car just decided to not run at all and will not start for the past few days. Then one of the coilpacks started bubbling out and melting after trying to spark it. Also the spark is orange not blue. Does anyone think the grounds I'm running aren't big enough? Or some other underlying issue? I'm sort of at a loss any help is appreciated
  • mpowerful
    • Jul 2013
    • 1273
    Sounds like you maybe getting power to them all the tine. Check power. Make sure they arent energized with key off.
    • helghit
      • Jun 2015
      • 29
      I'll definitely check that out today thanks for the suggestion!
      • 2mAn
        SeƱior Mod
        • 21014
        Maybe try getting the correct ground wire
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • helghit
          • Jun 2015
          • 29
          I just picked up the right ground wire yesterday so I'm going to put it on today and see what it does mate, thanks
          • M3PO
            • May 2012
            • 537
            A ground wire is a ground wire. You have something else going on. My guess would be that it's a DME issue.
            • helghit
              • Jun 2015
              • 29
              Well according to a few others the coils must be grounded 1-3 and 4-6 correctly through the valve cover or they wont be grounded right and start running back to the dme. Which it did and toasted my computer so I'm on the hunt for a new one. Also I think I located a short through the 4th coil pack so I'm trying to figure out how to deal with that
              • M3PO
                • May 2012
                • 537
                My point was you can use any wire to ground the coils. And grounding all of them is the best possible scenario. Typically, the coils are bridged/grounded together with metal brackets and then the straps ground the two groups of coils. If the coils weren't grounded, that may have damaged the DME which then, in turn, damaged the new coils you installed.
                • helghit
                  • Jun 2015
                  • 29
                  Ah okay, I didn't know if I needed a certain gauge wire or something because I had them all looped together but it didn't seem to work. I think I have a short somewhere in my harness or something is either missing a ground or grounded that shouldn't because it seems like coil 4 is the only one getting hot even when I switch it out.
