Swapping from OBD2 Valvecover to OBD1
  • 2mAn
    Señior Mod
    • 21038
    Im about ready to do this, but want to make sure I have covered all my bases to do it right the first time. This is more or less for anyone else thinking about doing this in the future and also a place for you to tell me what Im doing wrong...
    Differences Ive noticed between the two Valvecover's
    -OBD1 valvecover is Metal compared to the OBD2 which is Plastic.
    -They have specific gaskets, so make sure you get the correct one
    -The OBD1 uses nuts to hold down the coilpacks where the OBD2 uses bolts.
    -They have specific routing for the corresponding wiring, not a big deal but just a heads up. I had to do a little trimming to use the OBD2 beauty cover with OBD1 wiring
    I already have the correct OBD1 valvecover gasket.
    I sourced enough nuts for the coilpacks to replace all the bolts that the OBD2 cover uses.
    Should I use RTV on the gasket so it doesnt leak. This seems to be a common problem and Im pretty sure my OBD2 VCG had some type of sealant on it when I pulled it off when we did the VANOs a while ago. And now I have a small leak :hitler:
    Will I encounter any surprises or am I good to go?
    PCV?? I think they are different
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    I've been curious about this as well. I like the idea of powdercoating the VC for bling, also makes it easy to cut threads into the crank vent to put an AN fitting to run a nice PCV setup.
    Any idea if I could run an OBD1 VC even though I'm OBD2? (would I just need OBD1 coil packs plus the coil pack harness?)
    Shadetree30
    • M3PO
      • May 2012
      • 537
      I used RTV on my VC (OBD1) and the oil pan. Just a thin smear of the oil resistant stuff.
      • kronus
        • Apr 2008
        • 13032
        only put RTV (actually better to use non-drying stuff like hondabond or hylomar) on the corners of the half-moons on the rear and the seams of the front cover up front, don't slather the thing in it. if it's a new gasket it won't leak
        cars beep boop
        • Sh3rpak!ng
          • Jan 2014
          • 2667
          +1 hondabond is good stuff, so is hylomar. Much better than RTV
          Shadetree30
          • spiDmang
            • 3941
            this is a lie.
            victor reinz VC gaskets can suck these black, hairy balls
            91' 318iS - S54/6MT Swapped
            08' E90 M3 6MT - Daily
            Originally posted by IronJoe
            Originally posted by 2mAn
            • 2mAn
              Señior Mod
              • 21038
              Im pretty sure the PCV is different also, I will try to fit the current PCV stuff before I attempt to swap everything over, but it would be nice if someone could confirm this
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • kronus
                • Apr 2008
                • 13032
                yeah way different
                cars beep boop
                • 328ijunkie
                  • May 2007
                  • 3961
                  why would you want OBD1 vc.
                  Check Us out on Facebook
                  Full Product Line Tuning
