M52 cranks, 3 types
  • mr2peak
    • 2388
    M52 cranks, 3 types
    Ok guys, I've found 3 different M52 cranks.
    11211433027 @20.95kg, with no application on realoem
    11211433026 @24.85kg, ‘97+ but with earlier applications listed
    11211709059 @24.85kg, superseed’s the one above.
    Who can shed some light on this? Most everything I've read suggests that there's an early crank, and a later M52TU crank, but my research has turned up 3 cranks. Did the early alloy blocks have a different crank than the early iron blocks?
    Drive it hard. Maintain it well.
    A Topless Memorandum
  • SkiFree
    • Jun 2011
    • 2766
    Based on my notes. the 20.95kg is the standard crank found in most US m52 engines. The M54 engine is also an 84mm stroke and fits the weight of the two later part numbers you list. (the numbers are the last three digits of the casting number on the cranks). Be interesting to find out anything more.
    ADAMS Autosport
    • mr2peak
      • 2388
      11211433026 is the non-tu m52
      11211433027 is also a non-tu crank,
      11211709059 seems to be the tu/m54 crank
      One of these non-tu cranks has shorter webbing on all of the counterweights. I think it's a non-tu alloy block because the e30zone guys seem to have them, but I can't find anything confirming that.
      • digger
        • Nov 2005
        • 6207
        i have a m52 crank from US Spec e36 328i from 1997 iirc (supposed to be non TU) which is a big counterweight version and the mass without the toothed wheel, bolt, washer, pilot bearing, and chain drive was 21.5kg using a set of bathroom scales of unknown accuracy at those readings. Id guess it might get closeish to 23-24kg with fully assembled.
        i bet the light ones are the small counterweight more common in euro spec engines. There is an awful amount of mass in the C/W and its all on the peripheral so acts like a heavy flywheel.
        • mr2peak
          • 2388
          Found another! M52 crank part number
          11211744979 @20.95kg
          I think this is the one that is listed
          and yes, these are all 2.8l cranks
