Hey guys I finally figured everything out after chasing around problems left and right, I started testing all connectors on DME and my problem was it did not get signal from ignition. I then traced the green wire, pin 49 from DME to end of the harness which connects to pin 6 on the e30, my harness was connected to pin 7 with another ground wire, so somehow signal would not go through, anyways I cut the harness pin 49 (green wire) and jumped it from there to the c101 pin 6 boom worked like a charm,
Sent from my SAMSUNG-SM-G890A using Tapatalk
