M50 Idling issues.
  • newman8r
    • Feb 2014
    • 683
    So to clarify, The car starts up fine. will idle and drive fine and all of a sudden I will not get any milage what so ever and It starts to miss. If I keep driving it, it'll end that loop and everything will work. It just goes through periods of running like garbage and then it'll be fine.
    • berlow94
      • Jan 2013
      • 1063
      Did you listen to anything that i said?
      The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
      • newman8r
        • Feb 2014
        • 683
        Sorry! Forgot to reply. I do not have a charcoal canister. I have one vacuum capped off and the other two on the throttle body in a closed loop ( a u connecting each other)
        • berlow94
          • Jan 2013
          • 1063
          If the vacuum line going to the tank is capped off then how is air supposed to get into the tank? As your fuel pump is pumping gas out, air needs to get in.
          Take the cap off of that line and put a small air filter on it.
          • newman8r
            • Feb 2014
            • 683
            I'll have to post a picture when I get off of work. There are 3 nipples on my throttle body. I think the vacuum line to the tank is just there. (No filter on )
            • berlow94
              • Jan 2013
              • 1063
              OBD 1 or 2 throttle body? There is only 1 vacuum port on there.
              The other 2 are for the throttle body heater and don't need to be capped or looped.
              • newman8r
                • Feb 2014
                • 683
                OBD 1, Oh okay. that's it. when doing the swap a buddy who helped looped them... so yeah, vacuum is capped off. and the vent is open with no filter going to the tank.
