M50S32 euro specs pistons and roads on M54 crank ?
  • MclubSport
    • Oct 2013
    • 170
    Hello. Can I put M50S32 euro specs pistons and roads on M54 crank ?
    Anyone tried this? Rods diameter : S50 51mm and M54 48.01 mm ( big side/crank side ). Is it true ? Also the rod from S50B32 has 139mm and M54b30 rod has 135 mm
    Now I have M54 crank , pistons and rods in M50 NV block...
  • Nisse Järnet
    • Aug 2013
    • 1221
    I don't think Euro S50 parts works with M5X engines.
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • kronus
      • Apr 2008
      • 13032
      the hell is a m50 s32
      cars beep boop
      • digger
        • Nov 2005
        • 6213
        Big end diameter is not compatible, pistons are bigger bore thus need a big overbore and the little end pin is 21mm vs 22mm on the 135mm rod m50/m54 so need to be rebushed to suit s50 piston.
        most just use the rotating assembly from m54 into m50. not sure on deck height differences etc
