Pulling motor, quick question
  • h0lmes
    • Nov 2026
    I know that this information is probably here if I look for it but I really dont feel like reading through through the 48 page thread again. I am going to be pulling the motor out of a 95 auto 325is this week. I dont want to have to go back and forth from the junkyard where the car is for parts that I forgot. So my question is, besides engine, harness and ecu what misc. parts do I need to pull off the car while I am there?
  • gazellebeigem3
    • Jun 2005
    • 3712
    the engine mounts or 'arms', whatever the fuck theyre called, radiator if its in better shape than yours, thats all i can think of.
    • FredK
      • 14763
      e36 throttle cable. I guess the e30 cable is too long or something.
      • The Fast One!
        • Jul 2005
        • 856
        I'm think my e30 cablr will work fine, it's lines up fine.
        just get any hoses, sensors, and accessories that you need in order for the motor to run safely.
        Mike Fritz
        • h0lmes
          Let me know if the e30 throttle cable works. I have a brand new one and it would be nice if I could just use that instead of using an e36 cable. Just one less thing I have to buy. Thanks.
          • The Fast One!
            • Jul 2005
            • 856
            I'll let you know tmorrow or saturday morning, since that's prolly when I'll actually get around to hooking it up.
            Mike Fritz
            • Bennetts22@aol.com
              • Jun 2006
              • 171
              my e30 is loose and riged. i will be using the e36 this winter when iam done driving it.
              • DanGillan
                • Mar 2004
                • 4061
                you need the throttle cable. engine mount arms. if you're not taking the trans as well, make sure you get the guide pins from the block to trans. you should be all set.
                Dan
                • mentaleeill
                  • 850
                  e30 cable is too long. i made a spacer and put it betwwen the adjusting nut and the bracket, works great for now but im gonna order the e36 one as soon as i get time to go to the stealer. just order a new one for the price its not worth using one that has been sitting in a junkyard for god knows how long.
                  • The Fast One!
                    • Jul 2005
                    • 856
                    yeah they are only 25 new on some places online, but I don't really see my e30 one being too long.
                    don't get me wrong I will switch it with a proper cable in a month or so, I just need something temporary.
                    Mike Fritz
                    • tonytony
                      Knee deep in poopie
                      • Jan 2004
                      • 3498
                      what guide pins are you talking about dan?
                      • cheades
                        • 632
                        He is talking about the ones that make it so the tranny lines right up perfectly centered. They are just kinda pushed into the tranny or motor and you can end up with none depending on where they stick.
                        holmes - you need the upper and lower radiator hoses, I would leave the radiator unless it looks new as the e36 ones like to get brittle and break.
                        • tonytony
                          Knee deep in poopie
                          • Jan 2004
                          • 3498
                          oh that's what i thought, but i wasn't sure, i figured it was permanately in there.
