M52 Single or Dual VANOS for turbo?
  • Archiem111
    • Oct 2015
    • 6
    I'm in the process of building up a m52 for my e30 with intentions of turbo down the track. I have both a e36 single Vanos head and a e39 double Vanos heads available. I am wondering which one I should choose.
    What are some pros and cons for each? And which one would you choose an why?
    And also should I bother flashing and tune the stock ecu or should I just go standalone from the start?
  • pazi88
    • Sep 2015
    • 584
    You can't fit dual vanos head to single vanos block. The coolant flow and passages are completely different. You will need whole engine.
    • 328ijunkie
      • May 2007
      • 3961
      Cant run Dvanos head on SVanos as stated above, you can however run Dvanos on a Svanos head with some work. I would run stock ecu as there are a number of setups offered that work great
      Check Us out on Facebook
      Full Product Line Tuning
      • Archiem111
        • Oct 2015
        • 6
        I've actually got both of the blocks available as well. I'm just trying to decide which one to commit to. Then sell off the other
        • exhaust
          • Jun 2015
          • 411
          If you're up for the extra effort, go with the double vanos. Be different!
          • Northern
            I like cupcakes & sh!tboxes
            • 5234
            Better/way more/cheaper cam options for single vanos. Tuning/flashing much more common/way more aftermarket support.
            Originally posted by priapism
            Originally posted by shameson
            • Archiem111
              • Oct 2015
              • 6
              Yeah I don't really intend on doing the tuning myself. So I plan on having it all professionally done. So im really trying to find out if there would be any benefits of having one over than the other?
              Yeah I'm not to sure about cams for dual Vanos. Do the s52 cams not work?
