Driveshaft CSB question
  • Bmw e30 Justin
    • 316
    I just bought a 1990 M52/ZF320 swapped e30. I'm going through the car and replacing a bunch of parts to get it track ready. I have the driveshaft out doing the rear subframe bushings and realized the e30 CSB on the e36 driveshaft is mounted in the factory E30 ordination. I have always heard you want it mounted backwards on the E36 driveshaft when using the e30 CSB.
    Can anyone give me a definite answer on this? I have tried searching and seem to get both answers.
  • f4tj0n
    • May 2013
    • 411
    The CSB does not change direction, meaning you do not point the front towards the rear end. The e36 driveshaft just joins in a different orientation as the e30 driveshaft. So instead of installing it on the back half of the driveshaft, you install it on the front half. I hope that makes sense. Might be vise versa, I cant remember. lol
    • 328ijunkie
      • May 2007
      • 3961
      ^That.
      Check Us out on Facebook
      Full Product Line Tuning
      • Northern
        I like cupcakes & sh!tboxes
        • 5279
        I don't know where the "Install the E30 CSB backwards" shit came from, but it pissed me off when I installed my driveshaft and noticed it had a kink in the middle.
        So yeah, install the offset E30 one facing the same direction it was on the M20 DS.
        Originally posted by priapism
        Originally posted by shameson
        • Bmw e30 Justin
          • 316
          Thanks guys!
