vaughnbannister's Turbo S50 Build
  • ak-
    • 12422
    #31
    I hate to bring up old news, but that's over rev damage :^)
    You should be able to legally get your money back - maybe invoicing him on the suit would be enough to scare him to get your money back! Happened to a friend of mine over a bad engine sale.
    But dude, looking good. We need more boosted motors around here 8)
    1991 325iS turbo
    • vaughnbannister
      • Aug 2012
      • 206
      #32
      Yeah, I'm realizing that :( I have no idea how though. Maybe my tranny is done now, I'll check. But also the oil pump nut was loose.
      I'm going to contact my lawyer and see what her opinion is. I'll keep you all posted on that!
      I agree! S50 in an e30 is fast, but some boost never hurt right [emoji14]
      - S50 Swapped E30 1/1 Mineral White -
      @vaughnbannister on IG
      • ak-
        • 12422
        #33
        Your trans should be fine :D
        1991 325iS turbo
        • vaughnbannister
          • Aug 2012
          • 206
          #34
          Any way I could check to make sure while its out? I have a back up one as well [emoji28]
          • exhaust
            • Jun 2015
            • 411
            #35
            I'm not sure how over revving would damage the trans and those ZF boxes are pretty stout.
            Bored, boosted M50 though, very nice. Any plans to use the M54 crank and make a stroker?
            • vaughnbannister
              • Aug 2012
              • 206
              #36
              I'm using everything forged s50 inside. And iirc, s50 cranks and m54's are the same. Yes?
              • exhaust
                • Jun 2015
                • 411
                #37
                Yessir
                • E30FreaK89
                  • Apr 2006
                  • 437
                  #38
                  Same thing happend to me, first s50 grenaded for some wierd reason, no money shift or anything. This second s50 i money shifted from fifth to first :(
                  Now im just so over feeding my car engines lol. Both engines blew out the sixth cylinder. fallowing your thread for updates :)
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5262
                    #39
                    M54 and the S52 share the 89.6mm crank, not the S50.
                    Originally posted by priapism
                    Originally posted by shameson
                    • vaughnbannister
                      • Aug 2012
                      • 206
                      #40
                      I FINALLY have some news to report on! Went to the machine shop today to have a look at how things are going. The head is all clean and just needs to be ported/polished and then resurfaced. Then assembled!
                      With the valves in and the double valve springs as well.
                      Here is a picture of my friends s52 block that just got finished. It's beautiful.
                      • Northern
                        • 5262
                        #41
                        aftermarket double valve springs? What are you running for cams?
                        • vaughnbannister
                          • Aug 2012
                          • 206
                          #42
                          I haven't quite decided. Everything is not really worth it for how much money it costs.
                          I'm still searching for something that will be perfect for my application.
                          • vaughnbannister
                            • Aug 2012
                            • 206
                            #43
                            And yes, they are supertech double valve springs.
                            • vaughnbannister
                              • Aug 2012
                              • 206
                              #44
                              Getting the meth set-up on it was as well. 6 nozzles should do! [emoji56]
                              • BMW_TUNER
                                • Jul 2006
                                • 1386
                                #45
                                Nice Meth setup. I think i will end up starting out with a single nozzle after the MAF. Did you upgrade your oil pump? Also which fuel pump are you planning on using?
                                1989 332IS -S-Fiddy Four-Some weight removed.
                                5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
