Originally posted by vaughnbannister
View Post
Turbo time for my S50 on a "budget"
1989 332IS -S-Fiddy Four-Some weight removed.
5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
When you lighten your rotating assembly does that mean, you can exceed the 7,200 RPM limit without destroying your motor.. Obviously faster to rev and I assume you get slightly more power? Maybe?Current
| '91 318is | M50b28 | Schrick | Racing Dynamic's |
Late 2016
| S50 Frankenstein Turbo Build |
Past
| '93 325is | '87 325is | '92 240sx | '92 GTI | '87 325e | '84 318i | '95 325is | '92 318is | '87 325i
Yocale.com
Originally posted by BMW_TUNER View PostSorry I meant to say that I got the clutch flywheel and new pressure plate today. I dropped the flywheel and pressure plate off to have it balances with the rotating assembly. I am figuring having it all spun is smart give the that I am taking a significant amount of weight out of the rotating assembly. My estimate is the new pistons are 297x6=1782 gram and the new rods are 489x6=2934. Factory piston weight empty is apparently 560x6=3360 and rods are 540x6=3240 so factory rotating assembly is 6600gram.
My thought on that is if the crank is balanced and the clutch is balanced then putting them together it should theoretically be balanced.- S50 Swapped E30 1/1 Mineral White -@vaughnbannister on IG
Originally posted by vaughnbannister View PostMy thought on that is if the crank is balanced and the clutch is balanced then putting them together it should theoretically be balanced.
The crank had to be spun again and rebalanced because I am pulling 4.2lbs out of my rotating assembly and the counterweights would be very far off as thats a 29% reduction in counter balanced weight. Less weight= faster rev and maybe a few more HP by the time they drill my crank into swiss cheese I will probably have 5 lbs taken out of the rotating mass. :devil:1989 332IS -S-Fiddy Four-Some weight removed.
Originally posted by 052JMK View PostWhen you lighten your rotating assembly does that mean, you can exceed the 7,200 RPM limit without destroying your motor.. Obviously faster to rev and I assume you get slightly more power? Maybe?1989 332IS -S-Fiddy Four-Some weight removed.
Powder coating is coming in one piece at a time.
Since I likely will not be running my S50 engine cover this red one is winning right now.
But the black looks sexy too.
Especially with the cover.
So I am now thinking about trying to shoe horn one of these in the upper mounting position. http://www.treadstoneperformance.com...=product_682361989 332IS -S-Fiddy Four-Some weight removed.
Originally posted by BMW_TUNER View PostI figured its a new Stage 3 Grip force flywheel and pressure plate so its probably pointless, but if there is any tiny bit they can do to the pressure plate (which is apparently not uncommon) then it costs me nothing.
Originally posted by BMW_TUNER View PostThe word is that Valve float is the big problem beyond about 7400. I will try to spin it as far as it will go and still make power. I know my head will flow to support it its just a matter of if the valves will open and close.Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30
Talked to the machine shop. Sounds like all of the parts are coming back to me or assembly at the tend of this week. Time to Order plastigage and clean room wipes. Are there any recommendations out there for RTV on the front of the head gasket.1989 332IS -S-Fiddy Four-Some weight removed.
