OBD2 codes - do I need a BMW specific scanning software?
  • MC Hammered
    • Jul 2008
    • 2076
    I am getting a misfire so I hooked up my VAGCOM cable I used for my old Audi, used the generic OBD2 scanning section in the software to get the following codes.
    Would I get better results using BMW specific scanning software? If so where would I acquire it?
    TIA for any information.
    Saturday,27,February,2016,17:31:13:28049
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.1.1
    Data version: 20150130
    Mileage: Repair Order: bmw
    Mode 03: Emission related fault codes
    Address 12 (Engine): 3 Faults Found:
    P0302 - Cylinder 2: Misfire Detected
    P0170 - Fuel Trim; Bank 1: Malfunction
    P1188 - Manufacturer specific code
    My 1989 e30 s52 Touring... this is Betty
    My 1989 325i vert (sold)...this is Nina
    My 1991 M5 (sold)... this is Veronica
    Photo comparison: OEM vs aftermarket windscreen for a convertible
  • CENTURION
    • May 2015
    • 372
    do you have the option of typing in your vehicle specs?
    I've used an app and Bluetooth scanner and that has worked for me.
    but those codes sound about right, relating to your issue.
    start troubleshooting that misfire.
    switch coils, check spark plugs, relays, etc.etc.
    • MC Hammered
      • Jul 2008
      • 2076
      Unfortunately I do not have that option with the generic OBD2 interface I have.
      I get basic real time readings, error codes and the ability to clear them which I have done.
      Will start checking things out this week.
      • 328ijunkie
        • May 2007
        • 3961
        We use OBDFusion Iphone App for most quick diagnostics. It doesnt pull in all BMW codes (like the 1188 fuel trim code) but will steer you in the right direction.
        Check Us out on Facebook
        Full Product Line Tuning
        • Northern
          I like cupcakes & sh!tboxes
          • 5279
          INPA is free, and pretty easy to find/install via guides on various forums.
          For the price there's nothing better, but a laptop+cable is much more cumbersome to carry around than an app on your phone, so you may not see the need for it.
          Originally posted by priapism
          Originally posted by shameson
