M50 OBD1 -> S52 OBD2 swap requirements?
  • cbr
    • Mar 2016
    • 30
    I've recently picked up an e30 with a M50 swapped into it and I'm trying to figure out what I'll need in terms of parts/etc to replace that motor with an S52 and convert to OBD2 at the same time.
    From what I've found I think this is what I'm looking at needing:
    - Engine (the oil pan is compatible, correct)?
    - Wiring harness
    - ECU
    - Emissions crud (charcoal canister, evap, etc)
    Is that it? It seems like an amazingly short parts list so I'm almost certain I'm missing a few key things...
    (and apologies if this has been covered elsewhere)
  • 328ijunkie
    • May 2007
    • 3961
    Don't need the emissions "crud"
    Just get the ecu flashed...
    Check Us out on Facebook
    Full Product Line Tuning
    • cbr
      • Mar 2016
      • 30
      Unfortunately I'm in California and want to keep it street legal...
      • 328ijunkie
        • May 2007
        • 3961
        We helped a member here "MrGreen" pass obd2 bar about a month ago.
        • ian e30 318is
          • Mar 2007
          • 1809
          Didn't know this was possible...I have been telling people the wrong thing for a couple months. How did you end up getting this to work? I was under the assumption that OBDI car needed OBDI engine and accessories.
          1991 LS1 Swapped 318is
          Instagram:
          https://instagram.com/saltybeast/
          LS Build Thread:
          https://www.r3vlimited.com/board/for...s-e30-ls1-swap
          • 328ijunkie
            • May 2007
            • 3961
            You have to keep the OBD whatever that came with engine.
            M/s50=obd1 m/s52+=obd2
            • 4DR_Lou
              • Jan 2011
              • 158
              I'm currently doing an OBII m52 swap. from the top of my head, you will mainly need the following:
              -OBII engine w/modified wiring harness
              -e34 m50 oil pan w/modified dip stick tube (alternately, you can tap the oil pan for the drain)
              -ECU w/deleted EWS (you can also keep EWS by wiring it up)
              -modified water temp sensor (Markertmotorworks.com has these in stock)
              -activated carbon canister
              -fuel pressure sensor
              -unmodified stock exhaust midpipe and catalytic converter
              -smaller lower control arms to clear midpipe
              -engine/trans mounts (i'm using Condor's kit)
              -328i driveshaft (mated to a zf320 transmission)
              -smaller brake boost to clear intake manifold (i'm using a modified Porsche 944 booster)
              i may be missing a few things...
              1990 325i - Current Project
              2007 Triumph Speed Triple 1050
              • cbr
                • Mar 2016
                • 30
                1. OBII engine w/modified wiring harness
                2. e34 m50 oil pan w/modified dip stick tube (alternately, you can tap the oil pan for the drain)
                3. ECU w/deleted EWS (you can also keep EWS by wiring it up)
                4. modified water temp sensor (Markertmotorworks.com has these in stock)
                5. activated carbon canister
                6. fuel pressure sensor
                7. unmodified stock exhaust midpipe and catalytic converter
                8. smaller lower control arms to clear midpipe
                9. engine/trans mounts (i'm using Condor's kit)
                10. 328i driveshaft (mated to a zf320 transmission)
                11. smaller brake boost to clear intake manifold (i'm using a modified Porsche 944 booster)
                I renumbered your list for conciseness but I believe numbers 2, 4, 7, 8, 9, 10, and 11 would be identical from an M50 vs a S52/OBD-II build? Of particular concern on that list would be the lower control arms, if I don't have to touch those I'd rather avoid it...
                • kronus
                  • Apr 2008
                  • 13029
                  there aren't any smaller control arms. I think he means smaller control arm bushings, like the Treehouse Racing ones.
                  4 is different, you need that one to connect to the OBD2 harness.
                  7 is different, the OBD2 midpipe has 2 O2 sensor bungs, 1 behind each cat. The OBD1 one just has 1. The part #s are also different, and a particularly anal referee will check.
                  the rest are the same.
                  cars beep boop
                  • cbr
                    • Mar 2016
                    • 30
                    Sweet! thanks!
                    • 328ijunkie
                      • May 2007
                      • 3961
                      4 is the same, you need a retreaded sensor on a m/s52 no matter running obd1 or 2 (assuming early 97 and up Cyl head)
                      • 4DR_Lou
                        • Jan 2011
                        • 158
                        Kronus and Junkie are both correct. It's been awhile since I touched my unfinished swap. It looks like Treehouse's website is no longer available, but the CABs are alternatively obtainable from Vacmotorsports.
                        You will also need the air pump and the other components that attaches to the device:
                        http://www.realoem.com/bmw/enUS/show...diagId=11_1540
                        There are build threads out there for passing bar.. you just have to do research.
                        One member that comes to mind is Arch4angel.
                        • 4DR_Lou
                          • Jan 2011
                          • 158
                          Looks like Vac no longer sells them either
                          bimmerworld has CABs for sale also:
                          http://www.bimmerworld.com/Suspensio...rm-Mounts.html
                          Please note: If you look into Arch's thread, he had to shave a few from the smaller sized passenger side CAB to clear the midpipe. Correct me if I am wrong, you can bend the midpipe a bit to clear the midpipe... but in the end, it all depends on the ref you get during inspection.
                          • kronus
                            • Apr 2008
                            • 13029
                            I asked my ref (after I passed) about how much modification of the downpipe is allowed (including bending or denting) and he said that if he can see any, he has to fail it. so, uh, don't go to that ref, I guess.
                            FWIW I had a good amount of clearance with stock OBD1 downpipes and THR knockoffs. (you can get them on ebay) The OBD2 pipes are bigger due to external heatshielding, but not quite that much bigger. maybe a 1/4" more diameter?
                            cars beep boop
                            • kronus
                              • Apr 2008
                              • 13029
                              on OBD1 harnesses there are two 2-pin plugs for the two water temp sensors. on OBD2, there is one 4-pin plug that goes to a combination sensor. because you'll need a e30 cluster temp sensor to have a reasonable water temp output, you need a harness that merges the two sensors into one plug.
                              so, yes, the sensor is the same, but you'll need to do some harness fuckery.
                              edit: you'll need to make basically the reverse of this harness
                              cars beep boop
