Running 3.0" MAF w/ TRM Tune for 3.5" Issues?
  • MikeK
    • Jan 2005
    • 2771
    Hi gang,
    After the swap, I realized i had the incorrect MAF size with the tune. What effects (negative or positive) will take place by running a 3.0" MAF w/ a tune from TRM that was for a 3.5" MAF?
    Here are my tune specs:
    TRM OBD-I Performance Chips (Displacement: 3.2 L
    Injector: 21.5 lb/hr
    Intake Manifold: M50/S50
    HFM: 540/Euro (800)
    Cams: Stock S52
    Flywheel: Stock
    Fuel: 93 Octane)
    Thanks in advance,
    Mike
    Toyota Pickup
  • 328ijunkie
    • May 2007
    • 3961
    Many. Obd1 or obd2? If obd2 just drive with it unplugged for a little till you get the right one
    Check Us out on Facebook
    Full Product Line Tuning
    • MikeK
      • Jan 2005
      • 2771
      Sorry, I forgot to mention OBD1. I should also mention that post swap, hooned around a bit (...to redline) to make sure the motor felt as it should. I'm hoping nothing too destructive took place internally.
      Toyota Pickup
      • Northern
        I like cupcakes & sh!tboxes
        • 5278
        Those two MAFs spit out different voltages at the same flow, the tune adjusts the MAF scaling to suit the new MAF... so your ECU is going to be on a trip.
        Originally posted by priapism
        Originally posted by shameson
