Well damn....
  • SnickleFrittz
    • Feb 2016
    • 12
    Well damn....
    So guys, I just finished my s52 swap, and I must say I can be more happy with the result... it's freaking awesome. But anyways, I had a the local driveshaft guy make to the 2 driveshafts I had work. I used my original shafts with the zf flange welded to it.. but the guy couldn't balance it for me!!! For some reason I do not know... but anyways, which driveshaft don't I need to be looking for??? I know what the write up says, I just need someone else to just verify and say "yeap, that's the one you need," or "I used one from this car," thank guys!!.
  • Northern
    I like cupcakes & sh!tboxes
    • 5247
    S52 with a ZF320? Run a driveshaft from a manual E36 328 or M3 with a 4 bolt diff. Swap the E30 CSB onto it, keeping orientation the same.
    I have heard of people running large guibo eta driveshafts as well.
    Originally posted by priapism
    Originally posted by shameson
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      I think theres someone selling an adapter plate to use the e30 ds with the zf320
      Sent from my SM-G920T using Tapatalk
      Shadetree30
      • SnickleFrittz
        • Feb 2016
        • 12
        thanks guys!
        Also I need the same shift linkage for the e36 m3 or 328i, right?? Could anyone confirm that as well, maybe even have a part number handy for it????
        • f4tj0n
          • May 2013
          • 411
          I used the linkage out of the E36 M3. There is also a difference between years. The earlier E36's had a different style shifter rod joint, therefore there is millimeters difference that might throw your shifter position off, or you might just not notice...
          • sweet3
            • Oct 2012
            • 752
            1987 BMW 325 Drive Shaft, Spin Balanced. Quality 1987 BMW 325 Driveshaft with Free Shipping and Full One Year Limited Warranty.
            This one with part# 20680
            The genuine bmw part number is 26111226210
            PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
