e30 m50 Turbo
  • ReaverJam
    • Sep 2005
    • 11
    e30 m50 Turbo
    Guys, I was in the process of turbochanrging my m20 motor when my gearbox gave up the ghost. I decided to go ahead with an m50 swap. Question, how many of you guys have done this? Anybody with a right hand drive e30 who has done this? What did you do about getting low compression pistons?
  • matt
    • 3732
    With right hand drive, the least of your worries is the low compression pistons... where are you going to put your turbo?
    • ReaverJam
      • Sep 2005
      • 11
      Well, most you guys (LHD) have the turbo below the manifold, I was thiniking of placing mine above the manifold...right on top.
      • C ///M
        • 1040
        Unless you plan on running some insane amount of boost, why not just run a thicker headgasket instead of different pistons?
        A ton of e36 guys run the .140" Cometic headgasket and have great success.
        332iS R.I.P.
        • BeirBrennerE30
          • 2740
          top mount in the e30 is the easier place to put it imho... you can also fit a bigger turbo up there too.
          You are still going to have to have some pretty trick exhaust routing though
          i have 8.5 CP pistons.. call them, they already have a set speced for the s50/s52 for turbo apps
          e30sport.net
          '06 M3 Competition - 6-speed
          '97 Range Rover Vitesse
