Quick M50 tensioner question
  • Beej '86 325es
    • 2639
    Am I missing anything here? It seems loose...
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
  • matt
    • 3732
    It's hydraulic. When it gets some oil pressure it'll pump right up.
    • Beej '86 325es
      • 2639
      so it's supposed to have that slop in it? I just want to double check. It just seems odd to have such a big tolerance between parts like that.
      -Brandon
      '86 325es S50
      For sale:
      • matt
        • 3732
        Oh, I dunno about that. I didn't wait for the pics to load. Did you check the Bentley?
        • Beej '86 325es
          • 2639
          Just looked through the Bentley, and I couldn't find any photos of the secondary tensioner torn apart. I bought this one from someone, and just want to make sure he sent me all of the parts.
          -Brandon
          '86 325es S50
          For sale:
          • Beej '86 325es
            • 2639
            bump for the morning "crowd"
            -Brandon
            '86 325es S50
            For sale:
            • puusitalo
              • Mar 2005
              • 21
              A bit hard tell from the pictures, but those two parts shouldn't have play. It seems (by pictures) that there is a gap of 1-2mm there.
              Petteri
              • 325Projectz
                • Jan 2005
                • 1956
                If you're building this motor, replace all of those parts.
                91 m3
                • Beej '86 325es
                  • 2639
                  Yes, there is a good amount of play. Those 3 pieces shown are all I was sent. Are these pieces that wear out?
                  -Brandon
                  '86 325es S50
                  For sale:
                  • 325Projectz
                    • Jan 2005
                    • 1956
                    Yep, they wear out. How does the chain slider look?
                    Edit: So wait, those pieces are new?
                    91 m3
                    • Beej '86 325es
                      • 2639
                      The slider portion looks to be in good condition. I bought them used...looks like I got screwed if I'm missing a piece. Those are the issues you run into I guess when you build an engine from scratch. Looks like I'll be buying a new one. :(
                      -Brandon
                      '86 325es S50
                      For sale:
                      • 325Projectz
                        • Jan 2005
                        • 1956
                        Here is a part number for one, 95 S50, 11311738700. I think they are relatively cheap.
                        91 m3
                        • e30_kid89
                          • Apr 2006
                          • 489
                          speaking of "tension" i notice while i pulled off my oil pan that the chain for the oil pump has some play in it....does it get tense with the hydaulic adjusters or should i get a chain tensioner for it?
                          • puusitalo
                            • Mar 2005
                            • 21
                            There is no tensioner for oil pump chain, but then again you just need the pump run with the engine and timing is not that important. Just make sure it's not loose enough to jump off. If you have a chance, then change chain and sprockets but i would not dismantle anything just to do it. Anyway it's a good to check the tension of oil pump sprocket nut !
                            Petteri
                            • puusitalo
                              • Mar 2005
                              • 21
                              I just installed one of these the other day. There seemed to be steel insert inside that alloy frame, where tensioner itself slides in&out. I don't know if it's possible to remove (&replace) it without breaking te part, though.
                              Petteri
