E30 S52 swap question. Please help
  • juanitoM3
    • Nov 2012
    • 2
    I am in the middle doing a s52 swap from a 97 M3 the motor cranks but won't start. I have a Dinan ECU and would like to use it without the original key and immobilizer. Is there any way this can be done??
  • 328ijunkie
    • May 2007
    • 3961
    You can use the ecu but it needs to be flashed to properly run in an e30.
    Check Us out on Facebook
    Full Product Line Tuning
    • SAS Parts
      • Apr 2016
      • 57
      You must Cut the EWS (BMW immo) from ECU. Or use complete system from e36 (ECU + EWS) Or megasquirt :) Only megasquirt can steering the vanos system, our SA ECUMaster EMU at this day don't do that (but is better then MS x5 times).
      World quality custom part's for your race/drift/drag BMW, in low cost money.
      https://www.facebook.com/Projects.SAS
      • Kev
        JMP Autowerkz
        • 1575
        Or flash.
        "Hard Work Pays Off"
        1991-bmw 325i (R3vvd)
        1990- 325 (mpowa)(GC)(track)(beast)
        1988- 528e (daily driven when track car broken)
