Wiring question. what do I do with all these extra wires?
  • bmwfan52
    • May 2016
    • 118
    ok, I have droped my s52, w/ m50 head in my 318is now its time for the wiring.
    I have bought the ebay connector and have plugged in the sensors.
    My wiring harness is from a 97 bmw m3 and i am wondering if i just reduce all the wires and crimp off the ends.
    the 318is harness i chuck correct?
  • 328ijunkie
    • May 2007
    • 3961
    You running OBD2 or OBD1?
    Check Us out on Facebook
    Full Product Line Tuning
    • bmwfan52
      • May 2016
      • 118
      im running obd2,
      I finally broke the e30 harness away from the car completely and started putting away the mess in the 318is wiring case and things are looking a lot clearer.
      am I going to run into any wires or relays that i wont need?
      I am considering mounting the secondary oil pump my friend says delete it, is that even possible?
      I am trying to pass smog with this car here in California will i need the secondary air pump for that?
      • 328ijunkie
        • May 2007
        • 3961
        If youre trying to pass smog you cant really strip much of anything out of the harness. We have done a number of smog legal harness. You should contact Mr. Green on the forums. We helped him with his smog legal harness and tune. He can explain to you what he went rhough.
        • 2mAn
          SeƱior Mod
          • 21038
          this might help get you moving in the right direction
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • bmwfan52
            • May 2016
            • 118
            im not worried about smog I just hard to tuck away the wires easily.
            I wanted to know if there are any wires i can eliminate, or is it better to work aroound all those wires everytine i want to take the manifold off.
            • ba114
              • Sep 2015
              • 364
              I ended up shortening alot of wires in order to fit under my 318i wiring harness cover. before i did this, the cover wouldnt clip in fully.
              RHD OBD2 M50b25 turbo build thread:
              http://www.r3vlimited.com/board/showthread.php?t=384800
              • Sh3rpak!ng
                • Jan 2014
                • 2667
                If you're not dealing with smog, there's a lot you can get rid of. Use common sense, double check your ETMs, and thin it out. I cut all unneeded wires all the way back to the ECU connector and I have tons of space under the covers. You'd be surprised how much extra bulk is there from the factory.
                Shadetree30
