finishing up an obd2 m52 swap into an 89 325i and im stuck on the temp gauge. i already have the m20 temp sensor installed in the m52 head but there is no plug on the obd2 harness. the obd2 engine harness only uses one temp sensor which i have plugged in to the obd2 temp sensor.
i tried researching several times, there doesn't seem to be very much info on it. thanks in advance
