e36 325is MC
  • h0lmes
    • Jul 2026
    e36 325is MC
    m50 swap + e36 325is master cylinder, yes or no?
  • KangamangusDriver
    • Aug 2005
    • 1870
    Negative ghost rider
    Either the E30 325IX booster/cyliner
    Or 320 booster I believe.
    Search for the details in the huge thread.
    • matt
      • 3731
      You don't want to use the iX master cylinder in a non-ix car.
      • KangamangusDriver
        • Aug 2005
        • 1870
        Curious? Thats what Im using right now.
        • matt
          • 3731
          Doesn't it have a different piston size front vs rear?
          • h0lmes
            Thanks. I would look in the thread but it's much easier to make a quick post then to read 50 pages to get the info I need.
            • alexbaby88
              • 219
              I'm also using an iX booster.
              In fact its the recommended booster to be used in M50 swaps by the boys at E30.de.
              • matt
                • 3731
                Don't confuse boosters and mastercylinders.
                The ix booster is the thing to use. (can also be found on older 7 series)
                The ix master cylinder is not. It has a different size piston front vs rear and it will throw your brake bias off.
                • h0lmes
                  Dont I need a different reservoir or somthin if I use an IX booster?
                  • DEV0 E30
                    • Oct 2004
                    • 8890
                    No offense but you should re-read the mega 24v thread to freshen up on the details. I've got 540 remote mount reservoirs from an E34 with my iX booster+M5 Master Cyl.. but you can do a cleaner setup I think. Eventually I'll look for some small reservoirs that can go on the firewall for a fresh and clean look.
                    • PiercedE30
                      • Apr 2005
                      • 4220
                      ^ that is a really nice setup. assuming, front, rear, and clutch reservoirs.
                      My 2.9L Build!
                      • X2theZ3
                        • Mar 2004
                        • 932
                        aww,
                        that's a cute resevoir.
                        • alexbaby88
                          • 219
                          My bad. I am using the iX servo with E32/M5 mc.
