E30M50: ltw flywheel options
The tip of the shaft that slides into the pilot bearing is a different size between the e30 and e36, but the splines that hold the clutch should be the same.
I just finished installing my ZF tranny today and I used my e30 clutch allignment tool, so I know the splines are the same.
The last swap I did for a customer, if I used a machined down e30 flywheel and clutch, with an e36 Getrag tranny.
So in conclusion, make sure to use the pilot bearing matched for the tranny, and use the starter matched for the flywheel. All the splines on the trannies are the same.
-Erik
So, based in my hands on personal experience, and having both trannies side by side on the floor of my shop, with both an E30 M3 clutch and an E36 M3 clutch disk, I can say without a doubt that in my case they were, indeed, different sizes. ZF input shaft is larger than the Getrag (in my universe, your mileage may vary).Comment
