Help with coolant leak on exhaust side of block
  • MC Hammered
    • Jul 2008
    • 2076
    I noticed some coolant staining on the exhaust side of the block and the coolant tank was down about an inch of fluid.
    I jacked the car and took a look underneath and saw what is shown in the pictures.
    - The head gasket was changed 4 years ago.
    - The car isn't overheating, there is no coolant & oil milkshake or oil in the coolant tank
    - No white smoke from exhaust
    - Checked spark plugs and they look OK, but is brownish stain on the nose of some of them mean I'm running a bit lean?
    - Looked at piston tops and they are black
    So any idea what might be the source of the leak?
    plug 1
    plug 2
    plug 3
    plug 4
    plug 5
    plug 6
    My 1989 e30 s52 Touring... this is Betty
    My 1989 325i vert (sold)...this is Nina
    My 1991 M5 (sold)... this is Veronica
    Photo comparison: OEM vs aftermarket windscreen for a convertible
  • Northern
    I like cupcakes & sh!tboxes
    • 5247
    Headgasket, just isn't between water/oil passages or cylinders.
    Originally posted by priapism
    Originally posted by shameson
    • 328ijunkie
      • May 2007
      • 3961
      HG. See this with VR HG's from time to time.
      Check Us out on Facebook
      Full Product Line Tuning
      • MC Hammered
        • Jul 2008
        • 2076
        Thanks guys for the information.
        I went to see my friend and borrow a pressure tester, while driving there I was paying attention to the coolant temps and saw them fluctuate between 88-102degC.
        When I parked the car we heard a hissing sound. Popped the hood and we could hear the sound of liquid evaporating as it hit the exhaust header, so a slow drip of coolant leaking externally from the HG is what we suspected.
