Get a vibration at 750rpm idle, but not at 850rpm idle?
  • MC Hammered
    • Jul 2008
    • 2076
    The tune I have idles great at 850rpm.
    I wanted to lower the idle, so I set it tonight to 750rpm and I get a very noticeable vibration. Touch the throttle to raise the rpm a bit and the vibration goes away.
    Does anyone have any idea what would cause such a vibration just from lowering the idle speed 100rpm?
    I am running AKG poly motor mounts if that makes a difference.
    TIA for any information.
    My 1989 e30 s52 Touring... this is Betty
    My 1989 325i vert (sold)...this is Nina
    My 1991 M5 (sold)... this is Veronica
    Photo comparison: OEM vs aftermarket windscreen for a convertible
  • pazi88
    • Sep 2015
    • 584
    Engine specs?
    But with poly mounts you will feel the engine shaking.
    • MC Hammered
      • Jul 2008
      • 2076
      USA s52 engine, stock injectors, M50 intake.
      • Northern
        I like cupcakes & sh!tboxes
        • 5288
        I'm running the FX Stage 3 flywheel/clutch combo, Condor mounts, and some other odds and ends.
        As of this spring I noticed that my idle was sort of rough(already bumped to 800RPM). Almost like a misfire every 2 seconds or something (which it might be, still haven't looked into it too much)
        Bumped the idle up to 900RPM, seems a lot better now, but still feel a little bit of something going on.
        Originally posted by priapism
        Originally posted by shameson
        • 328ijunkie
          • May 2007
          • 3961
          I put most swap tunes at ~820. Happy medium. lower and you can get severe FW chatter and or NVH.
          Check Us out on Facebook
          Full Product Line Tuning
          • MC Hammered
            • Jul 2008
            • 2076
            Thanks for this feedback. So it is the FW that is creating this harmonic?
            • 328ijunkie
              • May 2007
              • 3961
              FW plus a number of other things.
