M50 starter clicks, but wont crank engine
  • Speedracer81
    • Jul 2015
    • 22
    HELP!!!!!
    I just took my m50 out of my other e30 and dropped it into a new one. that car was running, and was even used as an occasional dd. After dropping the engine into this new e30, and doing all the basics to test start it, I tried to turn the engine over with no luck. I checked all my grounds(or so I think) and they were all good. I had a spare starter so I took of my manifold, and put the new starter in and the then still wouldn't crank. at this point it hit me that I never connected the big black wire(the starter's main power source). I hooked that up to power then the engine immediately engaged and cranked.
    I reassembled the manifold, and then went to start the engine. the same problem came up. The starter would click once, and not crank the engine.
    So just to summarize.
    I have a new starter
    Grounds look fine
    Fuses are not blown
    I have 13v at the starter
    It cranked twice, now it won't
    battery is fully charged(I have two both have same result)
    PLEASE FOR THE LOVE OF THE LORD HELP ME
    thanks,
    Cameron
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5600
    Relay?
    • Speedracer81
      • Jul 2015
      • 22
      Relay?
      Would the starter still click, and try to engage if the relay was busted?
      Thank you for the reply!
      • m3boost
        • Oct 2005
        • 110
        Did you connect the chassis ground?
        88 e30/s50 gt35r turbo m3
        96 gt4094r turbo m3
        452 rwhp, 455 rwtq at 14 psi 91 octane
        681 rwhp, 684 rwtq at 25 psi E65
        • george graves
          • 20003
          The usual first step in trouble shooing a starter is to smack it with something heavy(I like to use a 3/4" 3' long breaker bar). A partial stuck solionid will cause a clunk but not a whirl.
          Originally posted by Matt-B
          • sweet3
            • Oct 2012
            • 752
            +1 for the chassis ground. That thing can cause the craziest problems. Should be located on one for the engine mounts.
            PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
            • Speedracer81
              • Jul 2015
              • 22
              Checked grounds for a strong connection. No Problem there. I did try the smack step with no luck.
              I'm wondering is there any quirky story any of you've heard of someone fixing a starter? I've checked every usual suspect, I'm willing to start trying crazy stuff!!!
              • m3boost
                • Oct 2005
                • 110
                Visual inspection is not the same as using an actual ohm meter to test ground connections. My chassis ground cable by the passenger motor mount bracket went bad. Visually it look good, but with an ohm meter the reading between my engine and chassis was 1k ohm which was enough for my starter to just click and not start and not turn over.
                96 gt4094r turbo m3
                • george graves
                  • 20003
                  You could always run power and ground to the starter with some jumper cables?
                  • Speedracer81
                    • Jul 2015
                    • 22
                    Very interesting. Where did you make the new ground? I will test ohms.
                    • Speedracer81
                      • Jul 2015
                      • 22
                      I did that while the starter was out of the car, and it worked fine. should I try this while its in the engine bay?
                      • Sea Aych
                        • Apr 2013
                        • 767
                        Clip some jumper cables from your oil pan to the body of the car and try to start it. If it does, you know it's a grounding issue.
                        I had a similar issue last week and tried the above. It ended up being not the grounding cable, but a grounding issue nonetheless, where the tab that the cable bolts to had a crack in it.
                        Apart from that, have you ohm tested your Crankshaft Position Sensor to see if it's in spec? That won't stop it from cranking, but if you get that going again and it still won't fire, that's what I'd check first.
                        1988 Atlantisblau Euro/Japanese 325i Cabrio
                        1989 Schwartz 325i - now M50 powered! - now very dead
                        1998 Toyota 4Runner Limited - gone
                        My 17,000km Big NA National Parks trip!
