vanos and non-vanos cam trays
  • e21jps
    • Aug 2011
    • 44
    Hi does any one know the details about m50nv, m05v and m52 cam trays?
    i heard some models have 35mm buckets and some models have 33mm buckets what models have what and are the trays interchangeable??
    this all becomes relevant when fitting big race profile cams
    I sell ITB's and performance parts www.racehead.com.au
    e21 race car m20 power! 293Whp atmo 2.9
    details here http://e21jps.webs.com
    drive by video http://www.youtube.com/watch?v=kOdPbErYlho
    incar race http://www.youtube.com/watch?v=sbr0ZCmjsYM
    incar video http://www.youtube.com/watch?v=aQyvDR-B00A
    drag racing http://www.youtube.com/watch?v=7XmznH6PND4
  • kronus
    • Apr 2008
    • 13031
    you should be able to find everything via search :p
    OBD1 cams can go in OBD1/OBD2 trays
    OBD2 cams can only go in OBD2 trays
    US S50 cam trays are weird and can take OBD2 cams despite being OBD1
    only NV motors got 35mm lifters
    cars beep boop
    • gearheadE30
      • Jun 2007
      • 3734
      If no one posts up here before the January 2nd, I have a set of 1993 M50 VANOS trays sitting on my workbench at home I can pull measurements off of.
      Worth noting that the 1995 M50 VANOS trays and lifters are different than the 1993 parts - 1995 got a better cam thrust bearing design, better oil feed passage on the #1 journal, lifters have a bit more internal volume, and oil feed hole in the lifter was redesigned. My 1995 cams also appear to be a higher quality casting than the 1993s, purely based on surface finish of the unground areas though.
      Project M42 Turbo
      • ForcedFirebird
        • Feb 2007
        • 8300
        The trays are interchangeable on the heads, but the cam has to match the tray, or you won't get full contact between the buckets and lobes, or can hang valves open. Early m50's (all) have 35mm, not sure when they changed exactly without a trip to realoem.com, but the s50 for sure had 33mm, and m52 (obd2) cars all have 33mm. Unsure if there was a difference between Euro and US markets.
        john@m20guru.com
        Links:
        • M3PO
          • May 2012
          • 537
          Which cams are you going to run? I run 286/272 on 33 mm lifters with no problems.
