S52 swap issue
  • Michael Star
    • Jun 2015
    • 286
    S52 swap issue
    Working on a friend's e30. Swapped from a m50 to a s52. No spark will crank but doesn't fire. Any ideas?
  • Northern
    I like cupcakes & sh!tboxes
    • 5277
    Swap to obd2 with the S52?
    EWS flashed? Does the ECU have power? CPS working/connected?
    Originally posted by priapism
    Originally posted by shameson
    • Jdmky
      • Jan 2017
      • 2
      Little backstory. The e30 had the m50 in it. I got ahold of a 94 318 m3 clone with the s52 swap. I'm swapping the motors between them. The s52 is converted to obd1. I don't think it would be a ews issue because there was no battery in the key for the chip. Still started and ran completely fine. And I've tried the ecu from both. I know I have power to the fuel pump and main relay. What would I need to check for power to the ecu. I also know I have 12v to everything that is on the terminal on the passenger side.
      • raj
        • Oct 2013
        • 100
        Can you run a stomp test? That is an easy way to tell you if you have power to the ECU (assuming the check engine light was wired).
        • pazi88
          • Sep 2015
          • 584
          Are you sure that the crank position sensor and cam sensor are plugged in right way around. In obd1 you can plug cam sensor to crank senor wire and vice versa because those share the same connectors. And if you do so, the car won't start. Very common mistake. In obd2 the connectors are different so that mistake can't happen.
          • BMW_TUNER
            • Jul 2006
            • 1386
            This.
            1989 332IS -S-Fiddy Four-Some weight removed.
            5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
