M52/ZF with 2.79 LSD?
  • BECKSTER
    • Jun 2015
    • 667
    I recently picked up a 2.73 LSD for a fairly good deal, and I'm switching my 24v setup from getrag to ZF.
    Will the m52 be gutless with the 2.73?
    Or is it useable?
    1990 Alpine 325is
    1992 Schwarz 325ic (sold)
  • CMBusch
    • Aug 2016
    • 181
    Or is it useable?
    It'd be good for going on long drives/road trips, but if you're going to the track or trying to race somebody it may not be ideal. It could be worse though, my current options are a medium case 3.73 open or a small case 4.10 lsd.
    Originally posted by Melon
    Engine work takes patience and finesse.
    Suspension work takes anger, a big fucking hammer, and a torch.
    • pazi88
      • Sep 2015
      • 584
      Yeah. For normal driving that rear end ratio might the best there is.
      • WAM3
        • Aug 2016
        • 28
        I had a 2.93 with ZF and it was good for highway but slow off the line. I changed to a 3.25
        • SmokeE30
          • 1730
          depends on tire size too but it would likely be a little longer than stock ZF gearing but not bad for keeping rpm down cruising.
          Shawn @ Bimmerbuddies
          Bimmerbuddies LLC
          717-388-1256
          2971a Roundtop Rd, Middletown PA 17057
          bimmerbuddiesllc@gmail.com
          • BECKSTER
            • Jun 2015
            • 667
            I'm running 16' wheels on a 205/45 tire.
            So I'm going to guess that's an ideal setup to run with a longer ratio diff.
            1990 Alpine 325is
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              ZF(1:15th) with a 2.93 ~~ G260(0.81 5th) with a 3.73.
              ZF with a 2.79 would be roughly like a G260 with a 3.46 if that helps you visualize...
              Good for road/highway use, not ideal for autox.
              Originally posted by priapism
              Originally posted by shameson
