M50 head coolant passages
  • JeLani
    • Aug 2015
    • 1552
    Cleaning up my m50 head to see if it can be used , and came across an oddity while doing so :
    It looks blocked , and I thought it was just some solid grease chunks but its metal .
    Every cylinder valve port except number 2 has this weird block on the left cooling pssage ? Anybody know what this is ? / could this head still be usable with or without work?
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
  • JeLani
    • Aug 2015
    • 1552
    1998 e36 328ic/5 -
    1967 2002 parts car
    1994 318iS junked.
    • RobTapps88
      • Feb 2017
      • 137
      ......... That looks like weld to me.. though I could be wrong.. new to BMWs here..
      Sent from my LG-H831 using Tapatalk
      • JeLani
        • Aug 2015
        • 1552
        I'm going to recycle this to scrap and get another head.
        1998 e36 328ic/5 -
        1967 2002 parts car
        1994 318iS junked.
        • RobTapps88
          • Feb 2017
          • 137
          Wait for someone else to chime in first lol that was just my 2 cents.. and if it is weld it can be drilled/machined out most likely. If you are still going to scrap it hang it in the man cave [emoji14]
          • JeLani
            • Aug 2015
            • 1552
            Originally posted by RobTapps88;4757740 . If you are still going to scrap it hang it in the man cave [emoji14
            Hahaha , table maybe? Glass top so I can see? Maybe if i come across a block thats bad too so it can be taller :)
            1998 e36 328ic/5 -
            1967 2002 parts car
            1994 318iS junked.
            • sweet3
              • Oct 2012
              • 752
              That's completely normal. Some heads are missing coolant passages there on the earlier models. That corrosion you're seeing is just electrolysis eating at the head. Not a big deal. You can either drill the holes open (might still need welding though), or grind the contaminants out and have it welded.
              Either way, it's still a good core if you purchase a rebuild head.
              PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
              • M3PO
                • May 2012
                • 537
                Yep, he is correct. The gasket has extra holes that don't isolate the head from the block and corrosion forms there. Just leave it alone. When the shop skims the head, most or all of that will go away. Not to mention, the new gasket will cause the same condition to happen again.
