Im new to understanding clutches as Ive never need to remove or even deal with them. I am swapping an e34 m50 motor with a 98 ZF trans in a month or so. I plan on using as much of the m20 clutch system as possible so I dont have to buy anything. I was told I need to shave the oil pan to make the M20 FW fit without issues.
Some have said I need the ZF pilot bearing no matter what.
Some people say that everything should bolt right up, while others say I need a 323 TOB.
If I use the M20's TOB then I need to use a spacer to make this work, what spacer do I need?
Am I missing something here what more do I need to buy to make this work? I think Ive spent to much time reading and have confused myself here.
