zf320 with m20 smf and clutch using stock 325i TOB, 328i clutch slave, new brass clutch pivot pin, and new ecs stainless steel clutch line.
I just got my driveshaft in and bled the clutch system using the system where you unbolt the slave and tip the bleeder screw up to the top and the clutch engagement is just like an inch or 2 off the floor.
just need to bleed some more? air in the clutch master cylinder?
should i have used the the euro 323i throw out bearing? could i just shim up the pivot pin a few millimeters and use and adjustable slave cylinder rod like this one?
do yall just let it be and live with the low engagement point? I kinda want a stock-isher feel to the pedal.
