Dropped the pan and found this!?!
  • MatRacer
    • 562
    Juste removed my oil pan to get it fixed and found what really looks like head bolt washer and a unknown plastic part broken from something... I did a head gasket job on this engine so lets say that the whasher could be from that job...but what about the plastic part? what could it be?
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • ForcedFirebird
    • Feb 2007
    • 8300
    Piece of the valve cover gasket that goes over the spark plug hole and center bolts.
    EDIT: Part # 11120034107
    john@m20guru.com
    Links:
    • MatRacer
      • 562
      It seem hard for a gasket... there is also a metal insert in it. It's made of plastic... nut rubber
      E30 now S52
      325xiT (Sold)
      • ForcedFirebird
        • Feb 2007
        • 8300
        Envoyé de mon SM-G903W en utilisant Tapatalk
        Yeah, that's what happens to those interior gaskets with heat cycles and being soaked in oil - they get rock hard and leak. That is the piece of the gasket that goes around the center bolts. Seen it more times than I can count in all the 24v engines. They are very hard to scrape/chip off and pieces fly everywhere.
        john@m20guru.com
        Links:
        • MatRacer
          • 562
          Than makes sense !
          Regarding the head bolt washer, I lifted the valve cover and it looks like the washer from the front right bolt is missing... so I must have dropped it when installing the head bolts... lucky it did not damage anything...
          Now, can I just remove the bolt and put it back with the washer? Should I use a new bolt? Since it's a bolt located on the corner, does it cause any additional concern removing it?
          Thanks!
          E30 now S52
          325xiT (Sold)
          • ForcedFirebird
            • Feb 2007
            • 8300
            Seeing that BMW had a head bolt recall and required the bolts to be changed out one at a a time in proper sequence, and it's a corner bolt, you probably will be fine to change it out and put the washer back in. Technically the bolt should be replaced, but don't believe you can purchase a single.
            john@m20guru.com
            Links:
            • MatRacer
              • 562
              Yeah, I will have to buy a set...
              Thanks for the good info!!!
              E30 now S52
              325xiT (Sold)
              • Matt-B
                The Waffler
                • 3856
                I also had a friend discover 1 of these, and he had lost his drain plug, so so needed 1 of those rubber temp plugs, and that had similar rubber bits. but most likely its gasket
                • M3PO
                  • May 2012
                  • 537
                  Fun oil pan surprises are the best! Last time mine had a zip tie and timing time guide shrapnel lol
                  • Todd Black 88
                    • Oct 2007
                    • 3449
                    That's nothing!
                    A buddy works for BMW and he has pulled a belt out of the oil pan of an X6!
                    Twice!
                    Apparently it gets sucked in through the front oil seal.
                    Originally posted by codyep3
                    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                    2001 silver/Blk 325 cabby. SOLD
                    2002 325xit Sil/blk. SOLD
                    2010 F650gs twin
                    • IceWhite
                      • Jan 2015
                      • 945
                      ^Common on the N54 motors.
                      1990 325i
                      2004 330i Individual 6-speed
