OBD2 S52 - Will I be using this?
  • RenaissanceMan
    • Aug 2004
    • 237
    Getting my harness info together for my S52 OBD2 swap and was wondering if I will still be needing/using this T shaped coolant pipe, or is there a cleaner way to run?
    Sent from my VS995 using Tapatalk
    '90 325is/S52
    '76 2002
    '74 2002tii
    '06 325i sedan
    '05 X5 3.0i
    '86 Alfa Spider Veloce
  • dude8383
    • Jan 2005
    • 10387
    That goes to your expansion tank. It works without getting in the way of anything.
    The one you'll want to close shut is the narrower line above it that juts out. It originally circulated coolant through the throttle body...
    • haaken675
      • Sep 2016
      • 601
      Do they make rubber caps or anything you could use to block off the small pipe that would have gone to the throttle body? Since this is already posted I might as well ask since I have been debating that one.
      • dude8383
        • Jan 2005
        • 10387
        I weld them shut.
        • RenaissanceMan
          • Aug 2004
          • 237
          Thanks for the info!
          '90 325is/S52
          '76 2002
          '74 2002tii
          '06 325i sedan
          '05 X5 3.0i
          • Klug
            • Sep 2011
            • 804
            I used a rubber hose and cap to close off the TB line on my s52, not the cleanest- but with all that CCV BS that is under the intake- it hides it pretty well.
            555Garage - Kingston, PA
            '13 BMW e70 X5 35d
            '95 BMW e34 525i
            '92 BMW e30 325i S52 Vert (Quade the Vert)
            '92 Range Rover Classic
            '90 Range Rover Classic
            '89 BMW e30 325i Coupe (The DIRTY30)
            '81 VW MK1 Rabbit Caddy Diesel
            '76 Honda CB550K Cafe/Brat
            '67 Pontiac LeMans
            '24 Model T Depot Hack
            ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
            • RenaissanceMan
              • Aug 2004
              • 237
              Is the line closed shut because there is no coolant port on the m50 TB? Or is there another reason for omitting it? I will be using an m50 manifold with an m50 TB. Thanks-
              '90 325is/S52
              '76 2002
              '74 2002tii
              '06 325i sedan
              '05 X5 3.0i
              • haaken675
                • Sep 2016
                • 601
                I think its just more of something you don't need. For example, I live in florida and have ZERO need to keep my TB from sticking closed in the cold and I wanted a port to install a temp sender, so I am deleting mine.
                • dude8383
                  • Jan 2005
                  • 10387
                  What haaken said. It doesn't get cold enough here to have to circulate coolant through the TB.
                  • BlackSpeed66
                    • Apr 2008
                    • 624
                    I snipped the ends of the small pipe on mine and had them welded shut. The car doesn't see snow here in Cleveland but I've had no issues that I've noted while driving during colder days.
                    -Geno
                    '87 325is (s52'd)
                    '95 525iT
                    '95 Jaguar XJR-6
                    '02 Range Rover 4.6 HSE
                    '98 Disco 1
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5277
                      I cut the TB heater pipe off, squeezed it flat, and welded it. Then I used the port in the head for a rethreaded E30 cluster coolant temp sender.
                      Originally posted by priapism
                      Originally posted by shameson
