The M50 cam trays need the M50 hydraulic lifters. As was already mentioned, the M50 has 35mm lifters and the S50/M52/S52 have 33mm lifters. You can use the M50 trays and M50 lifters with S50 cams if you want. No, the S50 cam trays are NOT the same as the M50 cam trays. They are, according to RealOEM.com, a different part number.
You can use the S50 trays with the M50 cams if you wanted to as well, but you would have to use the S50 lifters too.
Do a Google search on S50 springs/retainers failing and then thank your lucky stars you haven't had a retainer failure yet.
Oh, and by the way, I have a full set of S52 springs/seats/retainers (fully matched set) for cheap if you want 'em. They've been sitting around collecting dust for 4-5 years now and I'll never use them.
