is a m50 swap worth it?
  • Mr.SWISS
    • Nov 2005
    • 1251
    #106
    Originally posted by BDSax
    Anyone know what this connector goes to?
    If it is coming from the HFM harness it is the purge valve connector. I want to get one of those.
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
    • BDSax
      Junkyard King
      • Mar 2006
      • 3593
      #107
      what the heck does that do? does it mount on the air box and is it needed?
      NEED SOME VINYL STICKERS???
      • FredK
        • 14752
        #108
        The purge valve is connected to the charcoal canister. It is an electrically operated check valve.
        You should have a vacuum line coming off the TB that connects to the purge valve. If not, you will have a vacuum leak. You can just plug the line if you want, if you don't want to run a charcoal canister.
        I don't see the need to remove the canister though. It weighs nothing, and prevents the venting of hydrocarbons into the air.
        • FredK
          • 14752
          #109
          Here's my wiring diagram. I have not verified the functionality of Pin 22 on the x20.
          I did the diagram by extracting info from the ETM for a 94 325i and an 89 325i.
          Argh I think I attached the wrong diagram! Will update later.
          • BDSax
            Junkyard King
            • Mar 2006
            • 3593
            #110
            did my plug, have a couple issues.
            E36 X20 plug
            3 - Brown/Grey (not connected) shows no wire in the chart
            4 - Black/Blue (not connected)
            5 - Black/Grey (not connected)
            6 - Violet/Grey (not connected)
            7 - Black/Violet (not connected)
            10 - No wire in it
            11 - Brown/Yellow (not connected)
            17 - White/Violet (not connected)
            e30 C101 plug:
            10 - Blue (not connected)
            16 - White/Black (not connected)
            20 - Brown (not connected) shows no wire in the chart
            • BDSax
              Junkyard King
              • Mar 2006
              • 3593
              #111
              well, finally updated my part/price list. Total for m50 and 5 speed swap so far
              Date Item Part Number Price
              09/10/06 Motor $140.00
              09/10/06 Motor Core $20.00
              09/10/06 Engine Wire Harness $15.00
              09/10/06 Motor Mount $10.00
              09/10/06 DME (Computer) $15.00
              09/10/06 DME Core $2.00
              09/10/06 Junkyard Labor $40.00
              10/16/06 Oil Pan/Oil Dip Stick $54.24
              10/26/06 Vanos Oil Line 11-36-1-703-464 $32.18
              10/26/06 Head Gasket Set 11-12-9-064-467 $107.57
              10/26/06 Water Pump 11-51-7-527-910 $44.64
              10/26/06 Thermostat 11-53-7-511-580 $20.16
              10/26/06 Thermostat Housing 11-53-1-722-531 $20.48
              10/26/06 Belt Idler 11-28-1-748-130 $24.55
              10/26/06 Seal Ring RAL 14x18 $1.30
              10/26/06 6- Spark Plugs NGK 2288 $23.28
              10/26/06 Motor Mount 11-81-1-132-793 $49.00
              10/26/06 Oil Pressure Sender 12-61-1-710-509 $6.76
              10/26/06 Water Temp Sensor 13-62-1-709-966 $11.66
              10/26/06 Pilot Bearing 11-21-1-468-742 $5.27
              10/26/06 Cooling Hose 13-54-1-735-173 $14.60
              10/26/06 Cooling Hose 13-54-1-735-174 $9.27
              10/26/06 Radiator Hose 11-53-1-726-344 $15.04
              10/26/06 Radiator Hose 11-53-1-708-499 $11.48
              10/26/06 Navel Jelly $3.15
              10/26/06 Engine Paint $7.82
              10/26/06 Paint $3.48
              10/26/06 Permatex Moto Seal $4.89
              11/01/06 Tranny,5 Speed Swap $100.00
              11/01/06 Bottom End Gasket Set 11-11-9-064-460 $89.62
              11/01/06 Exhaust Studs 11-12-1-744-057 $5.76
              11/01/06 Exuast Nuts 11-72-1-437-202 $9.60
              11/01/06 Bolt and Washer 07-11-9-901-787 $0.48
              11/01/06 Gasket 11-41-1-703-947 $1.40
              11/01/06 Suction Pipe 11-41-1-748-150 $23.60
              11/06/06 Driveshaft Center Bearing 26-12-1-225-152 $34.01
              02/21/07 M8x1.25 Helicoil Kit $31.93
              03/12/07 Clutch Release Arm 21-51-1-204-229 $7.41
              03/12/07 Clutch Pivot Pin 21-51-1-202-659 $0.72
              03/12/07 Clutch Kit KF296-01 $184.25
              03/12/07 Clutch Slave Cylinder 21-52-1-116-300 $39.20
              03/12/07 Clutch Master Cylinder 21-52-1-156-000 $63.19
              03/12/07 Guibo 26-11-1-225-624 $35.19
              03/12/07 Shift Lever Bushing 25-11-1-220-600 $5.09
              03/12/07 Selector Rod Washer 25-11-1-220-439 $0.84
              03/12/07 Input Shaft Seal 23-12-1-220-619 $7.20
              03/12/07 Output Seal 23-12-1-205-340 $5.51
              03/12/07 Brake Resivoir Grommet 34-31-1-163-464 $3.16
              03/15/07 Brake Resivoir Grommet 34-31-1-163-464 $3.35
              03/15/07 e34 Throttle Cable 35-41-1-160-609 $23.04
              03/15/07 spring 21-51-1-204-327 $1.10
              03/15/07 Circlips 25-11-1-220-379 $1.24
              03/15/07 Bushing 25-11-7-519-669 $6.64
              03/15/07 Shift Lever Bushing 25-11-7-527-252 $51.16
              03/15/07 Wiring Cover 51-71-1-380-391 $13.92
              03/15/07 Wiring Cover 51-71-1-380-392 $18.76
              03/15/07 Bolt 11-22-2-243-051 $1.80
              03/15/07 Connector 11-61-1-738-629 $4.00
              03/15/07 Mount 11-12-1-730-356 $26.16
              03/15/07 Rubber Boot 13-54-1-738-757 $16.32
              03/15/07 Hose 13-41-1-738-186 $10.96
              03/15/07 Hose 13-41-1-738-185 $8.48
              03/15/07 Remote Brake Resivior 34-32-1-160-576 $72.68
              03/15/07 Tranny Bolts 23-00-1-222-890 $1.72
              03/15/07 Tranny Bolts 23-00-1-222-893 $1.72
              03/15/07 Tranny Bolts 23-00-1-222-887 $3.44
              $1,627.47 Total
              • skatebline
                • Sep 2006
                • 167
                #112
                you can use either a e34 or e36 throttle cable correct?
                • BDSax
                  Junkyard King
                  • Mar 2006
                  • 3593
                  #113
                  i read e34, so thats what i got
                  • Erick
                    Official R3V Drifter
                    • 11169
                    #114
                    Not a bad price. :)
                    ..::Support FullOpp::..
                    FullOpp Stickers for sale!
                    Feedback Thread
                    • MIKe30
                      • Sep 2006
                      • 2334
                      #115
                      update?
                      • Mr.SWISS
                        • Nov 2005
                        • 1251
                        #116
                        Originally posted by MIKe30
                        update?
                        Y do you need it????
                        :nice:
                        • MIKe30
                          • Sep 2006
                          • 2334
                          #117
                          ohhh, no particular reason :mrgreen:
                          :giggle:
                          • BDSax
                            Junkyard King
                            • Mar 2006
                            • 3593
                            #118
                            wow, i have fans!
                            its pretty much on hold til i fix up my M535i. It needs brakes fixed (no boost) which i think i have the part for it, then i need to swap a transmission.
                            After thats all done then i need to teach my wife how to drive a 5 speed so she can stop driving my e30. so im guessing i have another month.
                            im also still in need with the final little odds and end parts.
                            • e30 gangsta
                              • 3877
                              #119
                              W00t get ready for me to start asking you never ending questions.
                              • mattdk318i
                                • Jun 2006
                                • 3953
                                #120
                                bump, I might be slow. But hows this coming?
