Oil temperature sender on s50
  • TWRViper
    • Apr 2006
    • 75
    Hey all,
    I have a e30 m3 cluster and a 95 s50 engine. I'm interested in connecting an oil temperature sender so the oil temperature gauge will work on my cluster. I bought a oil temperature sender for e30 m3. Any suggestions where to install it?
    Some people say at the oil drain plug. I don't really like that idea (but am open to it) since the wire might get caught on some brush and I would have to remeve it everytime I do my oil.
    The other idea I have is to tee it off the oil pressure sender. However, I have yet to find meteric tee adapters.
    Any ideas?
    Tom
  • Van Westervelt
    • 9365
    They make the oil filter caps that are tapped for sensors already. That would seem like the easiest place. I think Turner had some spendy ones, but I have seen them a few places.
    • matt
      • 3732
      Turner has a fitting that goes where the oil level sensor would be on the 5er oil pan. Put it there.
      • Rev Engineer
        • Jan 2006
        • 162
        I looked through Turner's website and couldn't find either of the parts mentioned. Anyone know the part number or name?
        • e304me
          • Feb 2006
          • 1374
          Any one know which cluster wire needs to be tapped?
          • Van Westervelt
            • 9365
            On an m3 cluster none. There is a three prong plug directly on the back of the tacho, its not exposed on 325 clusters, just the m3 one.
            • e304me
              • Feb 2006
              • 1374
              so what do those 3 wires need to be? one from the sender, one gound and one positive?
              • matt
                • 3732
                http://www.turnermotorsport.com/html..._ID=TEN9990001
                • e304me
                  • Feb 2006
                  • 1374
                  3 Series E36 (Euro M3 3.0 and Euro M3 3.2 Only!)
                  • LINUS
                    • 2422
                    I have the linked oilpan flange - $75 shipped
                    As above, new in package from Turner. I think you get a better read on temp at the pan, but I chose to run my oil level sender and to machine a part to go up by the oil filter (1 off part).
                    LMK if you want it, PM's checked every other day.
                    ---Ben
                    It's not how you handle the good times, but the faith you keep in the bad that defines you.
                    • ///Mpressive
                      • Mar 2006
                      • 192
                      Yeah, but are you using a 3 series oil pan, or a 5 series pan like the one in the list of applications?
                      08 Toyota FJ Cruiser, Rock Sliders, Mostly Stock for now, parts on the way....
                      97 Toyota Land Cruiser FZJ-80, Front Bambi Basher w/ 2x100w PIAA's, mostly stock
                      • matt
                        • 3732
                        Beat me to it.
                        • Rev Engineer
                          • Jan 2006
                          • 162
                          ---Ben
                          Can you give some details on the part you made? I think I'll skip dropping $75 on Turner's machined piece. I could make one of thoes myself and I'd also like to keep the oil level sender.
