ZF Transmission and driveshaft don't work
  • lolcantturn
    • 4588
    I'm using a ZF out of an E39 528i, and I have an ETA big guibo driveshaft, but the two don't seem to mate up. I thought these were a direct fit for each other? Or is it because the ZF is coming out of an e39 rather than a e36 that's making the difference? Thanks
    Looks like the output flange are the same exact part number on the E36 and E39.
    Originally posted by TSI
    OEM+
  • lolcantturn
    • 4588
    Update: How weird. I have one of the very few ETA's that had a small size (110mm) guibo. PO was meticulous with his maintainence records and I can't find anything that points to the transmission being swapped or the driveshaft/output flange being swapped out in it's past life. How about that.
    OEM+
    • FredK
      • 14764
      Yes. The big flex disc (LK=96mm) started in 5/86, so earlier etas had the LK=78mm flex disc.
      • lolcantturn
        • 4588
        Interesting! Good to know. Thanks!
        OEM+
