Failed smog badly, any suggestions?
  • jayuuey
    • 414
    I attempted to get CA BAR certified today but failed smog terribly. Any suggestions on where to start?
    S50 out of a 95 m3, 04/1994 production date, 172k. Head appeared to have been redone at some point.
    506 dme, stock tune
    Typical reseal minus head gasket
    New knock sensors
    80 deg thermostat
    Cone filter on MAF (passed visual since obd1), new intake boot
    Oem mid section (low miles according to seller)
    O2 sensor likely original to midpipe/cat
    E36 rear section
    Runs good, idles fine.
    Thanks.
    Sent from my VS988 using Tapatalk
  • 2mAn
    SeƱior Mod
    • 20305
    Id start by replacing the o2 sensor, especially if its the original! The NOx is BAD though
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • Daeldalus
      • Nov 2012
      • 304
      The colder thermostat likely has something to do with it too. The stock tune is set for a hotter thermostat. A colder one would cause that tune to run a bit rich.
      • DesertBMW
        • Aug 2011
        • 1028
        80 deg thermostat
        80f is low for thermostat in my book, that will make the CO and HC higher than normal. Cone filter directly on MAF will mess up the reading, got to have some piping after the filter to smooth out the flow of the air. NOX is high also. When all 3 fail is good indication catalytic converters are bad.
