Need R3v gurus, 1 or 2 cylinders running rich, Hesitation below 4k, out of ideas
  • Sladek
    • May 2016
    • 228
    I'm trying to figure out what would cause one or two cylinders to run rich in my OBD1 S52. Been chasing a problem for months with hesitation until 4k rpms and done about everything i can think of, one thing that hasnt changed is cylinder 6 spark plug shows rich condition and cylinder 4 looks a tad rich but not as much
    Things to note:
    -Compression check good (less than 5 psi difference across all cylinders)
    -leakdown provided no answer, everything good with nothing out of the ordinary
    -checked for vacuum leaks multiple times, home made smoke test and essentially dousing everything in carb cleaner showed nothing
    -replaced maf
    -rebuilt vanos
    -replaced crank and cam position sensor
    -replaced coolant temp sensor
    -replaced intake temp sensor
    -replaced injectors twice (both new sets)
    -replaced and swapped around coil packs (no change regardless)
    -replaced spark plugs twice (both new, checked gap each time)
    -replaced fuel pump, filter, and FPR
    -replaced o2 sensor (have a new bosch sensor to try too)
    -replaced ecu
    -installed new sssquid chip
    -tried different known good ICV
    -replaced battery
    basically everything electronic and fuel related has been replaced and mechanically the engine seems great, just not under 4k. after a battery reset the idle searches and will dip when coming to a stop until after some time learning. then from a stop and cruising it hesitates and bucks until above 4k. i initially thought is was the vanos but after a rebuild the problem still exists. it seems like the initial battery reset idle problem and the hesitation are related but not 100% on that. its awesome above 4k but cruising on the highway and from a stop its terrible
    i need the r3v gurus help on this, im about to hesitate this POS into a wall. the only thing electronic left to replace is the knock sensors and the wiring harness (which i have both) but was wondering if anyone had any input.
    spark plug picture and video will be in next post
    update: redid timing and main exhaust sprocket seemed off a tooth so moved it according to the pelican procedure and now all are rich, still has hesitation
  • Sladek
    • May 2016
    • 228
    cylinder 1>>>cylinder 6
    more used set up front, newer set in background
    • Sladek
      • May 2016
      • 228
      both of these were going WOT from cruising. the first video it's hard to hear but watching the tach stay still it's hesitating the whole time and then finally starts accelerating. the second one is a short buck.
      hard to get a video from a stop
      • TobyB
        • 5298
        My initial reaction is to flow test your injectors.
        4 and 6 look rich, which really means 5 is lean...
        <edit, well, wait, if you've swapped them and that pattern persists, I'm wrong about that>
        I've been messing around with m54s too much recently, but if the cam position sensor is
        inaccurate (like, maybe out of phase? I'm really guessing here) would THAT mess up how
        the ECU is trying to match flows on individual injectors???
        fwiw,
        t
        • Sladek
          • May 2016
          • 228
          fwiw,
          t
          yeah both sets of injectors are new and flow matched, but i do wonder if maybe timing/cam phasing is off slightly and thats causing some sort of issue, if that would even be a symptom
          • Sladek
            • May 2016
            • 228
            anyone else have any ideas?
            • Sladek
              • May 2016
              • 228
              redid the timing, seemed like main exhaust sprocket was off one tooth (slots were in the middle and adjusted to the left like in the pelican article)
              still runs like crap under 4k but now all the cylinders are running super rich. still searches for idle when clutch in coming to a stop or if i blip the throttle while sitting itll search before settling in a 1000 to 1100rpms which seems high to me
              • 36brua
                • 689
                Are you using BMW OEM CPS and cam sensors ?
                My CA legal M60 swap
                The happening in our garage
                • Sladek
                  • May 2016
                  • 228
                  yep, straight from fcpeuro
                  • ZekeTheSneak
                    • 1562
                    when you turn the ignition on to run but do not crank it. Can you hear an injector click and fire off? As in squirting fuel?
                    • Sladek
                      • May 2016
                      • 228
                      hard to say sitting in the car, should I? starting isn't so much of a problem as much as the hesitation and running rich. I don't think they are stuck open either
                      • ZekeTheSneak
                        • 1562
                        No they shouldn't click with the key turned into the on position. But if they do click then the dme injector controller died. Happened to me. It like flooded the cylinder though. Gas was pouring out of the exhaust
                        • Sladek
                          • May 2016
                          • 228
                          i guess ill check that out. ive changed the DME out so i doubt it would happen on both unless something is frying it with wiring. cant hurt to check
