m50 power wiring, need assistance
  • LooN
    • Jul 2006
    • 37
    Originally posted by matt
    I think your battery is dead.
    100% charged, left it on last night and all day today, all the lights in the car are extra bright now. still does the same thing :(
    Originally posted by Brew
    Any chance you forgot to ground the engine block? The right side motor mount to the ground point on the frame rail is good location.
    just checked, engine block is grounded
    Originally posted by Rev Engineer
    I think you're shorting something out at the starter. When you move the key to the "start" position, the primary thing that happens is +12 getting applied to the black/yellow wire. Maybe the black/yellow wire is connected to a ground point on the starter? Or, maybe the starter is bad and shorting it's +12 wire to ground via the solenoid?
    How possible is this? That the starter is bad and its shorting its +12 wire to ground via the solenoid? Happened to anyone before? At this point I think its a possibility because after checking a ZILLION times, I'm 99.99% sure all my wiring is correct.
    Everything turns on and works when key is in the "on" position. When I turn it to "start" position, there is a loud KACHUNK as all the electricity grounds to the chassis (that is what's happening, as far as I can tell). Everything goes dim for about a half second, then *CLICK* everything goes on again. The delay is very precise--could it be a relay of some sort??
    ARe there any fuses in the car besides the fusebox? I heard the main lead from the battery has two wires--one thick, one thin, and that the thin one is fused. WHere is it fused? THe wires disappear behind the upholstery in my trunk.
    Thanks everyone for all your help so far!!
    LooN
    • cahomey
      • Mar 2004
      • 1201
      Originally posted by clavinZERO
      we JUST went through this tonight ourselves... on that A/B pic stuff: slit the jacket open and peek in... red = go to power distro block, black/brown = ground that thing. check that out.
      "It's like a koala bear crapped a rainbow in my brain."
      R.I.P. Harry Goz aka. Captain Murphy
      "My ride, My ride, she don't beg, steal, cheat, or lie,
      My ride, My ride, and our relationship is classified."
      • LooN
        • Jul 2006
        • 37
        cahomey i already did that 3 days ago, thats no longer my question/problem
        • DEV0 E30
          • Oct 2004
          • 8903
          I had a dead cell in my battery, get it tested.
          Try to manually turn over the engine by hand. 22MM wrench on the front, remove radiator for ease.
          • LooN
            • Jul 2006
            • 37
            that's another thing i was thinking about checking, would a battery with a bad cell still provide adequate power to turn on everything else, just not crank?
            • DEV0 E30
              • Oct 2004
              • 8903
              1 bad cell did that to me.
              Even being jumped by another car.
              Car would barely crank, then couldn't even do that.
              Make sure you can turn over the car by hand though, you could have the same problem as me. The flywheel was resting on the back of the block and couldn't move.
              • Mike B.
                • Jan 2006
                • 987
                Have you check the outputs off of the main relay with the key in start position? What are the voltages?
                • LooN
                  • Jul 2006
                  • 37
                  I need to make something clear...not sure if people aren't reading or it doesnt matter, but when I turn the key to start position there is a VERY LOUD electrical-sounding *THUNK* (I can actually feel the whole car jerk) and ALL the lights in the car go OUT, except the speedometer and tach which go VERY dim. After a very precise delay (its the same every time), about half a second, there is a loud *CLICK* and everything turns on again. Forgive me if I'm a little scared of testing any voltages with the key in the "start" position when this is the case.
                  Before I replaced the wiring harness, the engine would crank STRONG and easy with the same battery and starter I am using now. I will test it with another battery tonight just to be sure, but I dont think the battery is the problem.
                  What's the best way to do this? Sorry for being such a noobie, but it IS my forum title ;)
                  A tech at my work who used to work at BMW of Bellevue (and who has a very nice E30, btw) told me to "divide and conquer" in order to find where the harness is grounding in the place it shouldn't be. He told me to do this:
                  -Disconnect the battery, and make sure the two disconnected wires weren't touching anything.
                  -Take an ohmmeter and connect one end to an unpainted chassis point (ground).
                  -Beginning at the starter, touch the other end to positive leads on the harness.
                  He said that if everything was connected properly, I should have "infinite resistance" at the starter positive lead (I'm assuming because there should be no connection between the ground and the positive lead?). However, I do get a resistance reading...is this my problem? Or would I get a resistance reading if everything was connected correctly? Should it just have a really, really high resistance between these points?
                  What is the best way to go about using this technique to diagnose my problem (assuming that a positive lead on the harness somewhere is grounded where it shouldn't be, and the battery is good)??
                  Thank you SO MUCH EVERYONE for all your help so far. I apologize for being such a pain. I just want my Ultimate Driving Machine to actually see some pavement. :D
                  LooN
                  P.S. if it makes a difference, this is a '92 non-vanos E36 body with a '95 vanos M50 motor
                  • hugh jass
                    • 2220
                    it really sounds like a dead battery to me. old batteries won't hold much of a charge. the easiest thing would be to take it to autozone where they can load test it for you for free.
                    i think i know the electrical 'thunk' you're talking about. it could be the starter barely turning over.
                    sorry if i sound like the others, but its always easiest to 100% eliminate the stupid things first.
                    ______________________
                    ex-Chief Operating Officer
                    Blunt Tech Industries
                    West Coast and Pacific Rim
                    • Rocla
                      • 922
                      Actually solenoid going on and off. When the solenoid feeds power to startermotor, voltage will drop dramaticly as starter tries to revolver. When voltage drops near to zero due dead battery solenoid will loose the contact and disconnect power from starter. After solenoid relases power from starter voltage will raise slighty, just enough to pull solenoid enaged again and cycle will start over again.
                      Result will sound like klick, klick, drrrrrrrrrrrrrr.
                      Sorry, I can't simulate sounds in english, in my language it would be
                      klok, klok päärrrrrrrrrrrr :)
                      Edit: you might try to jump it, if result is same, try jumping it with your negative battery cable removed from battery. That includes a small risk of damaging electronics of your car. I've done it like 100 times without any damage, but there is as risk.
                      Current:
                      BMW 320i 2d 2.0 m20 -88
                      BMW 325i Cabriolet 2.5 m50 -88
                      BMW 316i touring 1.6 m40 -90
                      BMW 320i 4d 2,2 m54 -01
                      • LooN
                        • Jul 2006
                        • 37
                        Thank you Rocla and hugh :) I will definitely switch out the battery with a good one when i get home tonight, hopefully the problem is that simple. If the battery is bad, could it possibly still hold a charge strong enough to FULLY power all electrical systems (headlights, interior lights, gauges, windows, etc) when ignition is in the 'on' position? Because that is what it's doing now..I charged it overnight and all lights on the car are now VERY bright.
                        If the battery is not the problem, can I use an ohmmeter with the battery disconnected to test if part of the engine harness is grounding where it should not be? What is the best way to do this?
                        Thanks again,
                        LooN
                        • Rocla
                          • 922
                          If there is short somewhere, it must be in starter motor itself. if your starter wire was grounded it would be constant short, not only when you try to crank it.
                          Also short that strong in any cable would create visible smoke and sparks.
                          You could also try to jump between starter main cable and that terminal where the black/yellow cable connects with a screw driver. Be careful, if you short main terminal and ground with screw driver the short circuit could weld screw driver between the contacts, cause battery explosion, or create enogh heat to set your car on fire or cause you major scald.
                          Shorting those terminals together would make starter to engage.
                          Are your battery terminals tightened? :)
                          Current:
                          • LooN
                            • Jul 2006
                            • 37
                            Ok so I just got finished replacing the starter with a remanufactured one from Bavarian, and no change. Tried using the battery from my friend's (running) E30 and still no change.
                            When I turn the key to the start position the voltage in the car drops dramatically as the power goes to the starter..all lights turn off or dim to almost nothing. The starter doesn't turn over at all. I am absolutely sure I have the wires connected correctly on the starter, power distribution block, alternator, and fusebox.
                            I tried holding the key in the start position to see if it would do anything, and the blasted starter motor began SMOKING. Like a freaking wisp of smoke curled up out of the engine. I nearly shat myself. Thorough inspection of the wires found no damage, thankfully.
                            At this point I don't know what to do. This car has been sitting in my driveway for two and a half months. I'm about to give up on my dream of owning a BMW and just part the thing out so I can buy a piece of shit Civic.
                            • tonytony
                              Knee deep in poopie
                              • Jan 2004
                              • 3498
                              this might have been mentioned already but did you try cranking the engine by hand? my starter wouldnt budge either until i figured out i seized the engine by bolting the crank pulley back on without the ac pulley attached, that made the bolts being too long and it dug into the block and kept it from cranking.
                              • LooN
                                • Jul 2006
                                • 37
                                ok tried it, engine cranks easily by hand
