I ran a voltmeter test on the main power terminal on the starter--the one with the fatty red wires that connect to the power distribution block and the alternator. With ignition in the "off" position, it read about 12.7v, and in the "on" position, dropped to about 12.4v. However, when I turned the key to the "start" position, the voltage dropped to 5 volts. I'm pretty sure that's not enough to engage the starter, which explains why it isn't turning.
I have ruled out the starter and the battery as problems, and all I've changed is the wiring harness (before that, the car cranked easily).
So my questions are:
-Where could this extra current be going to?
-When the ignition is turned to the "on" position, does anything else happen besides +12v being applied to the yellow/black wire on the starter?
-Could a faulty relay be the problem?
-Could a faulty alternator or alternator connection be the problem?
Thanks for all your help guys...slowly narrowing this down.
LooN
LooN
