S52 and flywheel w/g260. What starter?
  • brads2002
    • Nov 2005
    • 2688
    So I was able to get my swap fired up and all seems well except for an occasional starter miss. I’m running an S52 stock dual mass with a G260 transmission. The starter was from the S 52. Nine times out of 10 it starts without issue. The 10th time I get some weird grinding noise. If I rotate the crank a little bit and try to restart it works. It’s almost like the flywheel had a couple bad teeth but the flywheel was new. I’m confused.
    Any advice appreciated
  • kronus
    • Apr 2008
    • 13032
    transmission doesn't care.
    starter should match flywheel. m20 flywheel -> m20 starter. s5x flywheel -> s5x starter.
    they have slightly different profiles.
    cars beep boop
    • brads2002
      • Nov 2005
      • 2688
      Hmm that’s what I thought. I can’t understand why moving the crank would allow it to hook up?
      • bradmer
        • May 2016
        • 362
        The s52 g260 swap I have is single mass.
        maybe this?
        • brads2002
          • Nov 2005
          • 2688
          Interesting. I didn't realize there were two thicknesses on the bell housing. I would think if that were the cause it would happen every start. Possible the starter was getting hung up on its own shaft making an ugly sound but i can't figure why turing the crank would help.
          • pazi88
            • Sep 2015
            • 584
            Your starter just has sticky solenoid and if the flywheel is at wrong posttion the starter gears don't engage. And grind agaimst flywheel gears. Replace starter.
            • brads2002
              • Nov 2005
              • 2688
              Cool, I am hoping that is the case too. Have a used one on the way to test it out. $12 eBay shipped to me. Not sure how they are making money on that one. Will report back.
