driveshaft question- S52 swap
  • smorales-e30
    • Nov 2016
    • 2
    I am putting an S52 with ZF 5pd in a 1986 325e.
    Keeping original rear diff for now.
    My original driveshaft has 4 bolts while ZF trans has 3 bolts.
    Do I need to replace the entire drive shaft?
    I purchased the Revshift e30 flex disk but it also has holes for 6 bolts.
  • Metallated
    • Dec 2016
    • 1074
    It best to stay away from the flex disc unless it is a dedicated track car, it will be super stiff and create tons of vibration and noise.
    You need to find a driveshaft from a 328i or an E36 M3 that has the same transmission.
    • Sea Aych
      • Apr 2013
      • 765
      Four bolt rear, three bolt front. I believe the late model E30 325e driveshaft also fits here. You'll need to use the E30 centre support bearing too, regardless of which driveshaft you pick.
      The flex disk always has 6 holes because the transmission bolts into 3, then the driveshaft is "offset", or rotated, to bolt in to the other 3.
      1988 Atlantisblau Euro/Japanese 325i Cabriolet
      1989 Schwartz 325i - now M50 powered! - now very dead
      1998 Toyota 4Runner Limited
      My 17,000km Big NA National Parks trip!
