M52B28 swapped - engine cut off when cold start
  • ecsk
    • Nov 2011
    • 106
    This happened recently to my E30 with M52B28 swap. Start the car in morning, idle drop immediately and die. I need to hold the throttle to maintain the idle for about 30 to 60 seconds, then it'll idle ok.
    Where should I start to troubleshooting ? I suspect it could be coolant temperature sensor.
  • Dgerry
    • Oct 2016
    • 54
    Check for vacuum leaks, closely check the hose that runs to the ICV. The intake boots can crack on these as well if you are using a stock style (non silicone). That is where I would start.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5616
      Yeah, check the temp sensor
      • haaken675
        • Sep 2016
        • 601
        I had something very similar happen to my e39 when I first got it. Previous owner thought it was vanos seals, which I replaced. Still had some cold start issues and I replaced the MAF and it mostly went away. I still had a hard time starting on cooler mornings, and I eventually arrowed it down to likely being a dirty ICV. I would try the ICV first and keep checking from there.
